Full Version: what shock oil to run???
xc1993
what are you oil are you guysrunning in your shocks im rebuilding my rear and have heard that a lighter weight helps fafind a bit what brand and weight do you suggest?
Nick @ JET Suspension
QUOTE(xc1993 @ Oct 28 2009, 05:33 PM) *
Depends on what the tuner has valved it too, but 5wt is pretty standard in rear, in some cases as low as 3, but this would require a change in the shim stack. Silkolene, Belray, or any synthetic or synthetic blend with a defoaming agent - most of which have some amount of defoamer. We use Silkolene and a couple of other brands and blends depending on what your doing with it.
xc1993
QUOTE(Nick @ JET Suspension @ Oct 28 2009, 05:51 PM) *
cool thanks a lot im may need parts do you guys sell springs pistons seals and things??
QUOTE(xc1993 @ Oct 28 2009, 09:19 PM) *
Yes and oil too, you can pm me
