951bulldog
Oct 4 2009, 11:47 AM
I have a 450r that has been sitting for about 6 months. Last time I rode it and put it away i forgot to add fuel stabilizer to it. So, what now? Do I need to drain it or is there an additive I canuse or what?
If i do need to drain, could you please explain exactly what it is i need to do as i have never done it before. Thanks a lot
tjsdaname
Oct 4 2009, 11:56 AM
if it were me, I would drain the gas tank....
what you need to do is, where you turn your gas on and off there is a hose running from the tank that plugs into it. just pull the hose off and let the gas run out into a bucket....
crazzylegs
Oct 6 2009, 07:34 PM
the gas in the tank should be good. it last longer in there.. i would drain the bowl tho. jus turn the fuel petcock off and on the side of the fuel boul there is a flat head screw. twist it out and it will drain the bowl
