Full Version: Hard to Find Neutral
Luke Heier
I just picked up a 2005 TRX 450R. It's my first wheeler. It has numerous mods to it. Full Sparks exhaust, high compression Wiseco piston, cam, and a few other things. Anyway, I am having a hard time finding neutral. It always seems to jump right to second gear. When I do find it, it stays in neutral just fine, but it's just a pain to find it. Is it normally that touchy?
GravelPit
When the engine is running it is rather hard and almost impossible to find neutral, if it's rolling, it's pretty easy.
turn the engine off and first try you'll find neutral, not sure technically why it does this, but it's normal.
tjsdaname
mine is the same way...
but like said above me, if you kill the engine it just slips into neutral
motoracer58
change your tranny oil, i could never get neutral in mine until i started running a 10w50/20w50 oils in mine
Don Andretti
It is the design of Tranny. My 05' 450R and 85' ATC 200X are the same. Changing tranny fluid does help, but when fluid goes bad you will notice it getting harder to find neutral
darmo21
I Had the same problem. Ever since I got my new clutch set up it has went away. And I change my oil often.
Scro
If you give it a little gas while its running, it will fall right into neutral.
Derek_Thompson24
You'll notice that if you shift to first, pull the clutch, and give it throttle the back tires will try to move forward about half an inch. The setup is pretty tight. Thats why when you are rolling it is easier to find neutral or if you give it a bit of throttle to force a "gap" its easier to find neutral. There isn't really a fix since it isn't a problem.
wolfpack
When my clutch gets a little tight mine is harder to find.
kschudy450r
when i first got my bike it went in to nu fine when i switched to rottella 15-40 it is hard to find nuetrall
redfour504life
QUOTE(Derek_Thompson24 @ Oct 27 2009, 09:37 AM) *
could this be the reason that it sometimes likes to slip into neutral from 1st to 2nd when accelerating hard?
