endlessrider
Sep 24 2009, 05:38 PM
I'm a newbie and the high beam points up in the trees; I'm assuming the lamp needs adjustment downward behind the lense and should illuminate the same level as the low beam? It is not supposed to tilt upward, correct? Thank you very much for your time & assistance?
jgardone
Sep 24 2009, 08:21 PM
pull the hood and then disconect your headlight and unbolt it. there should be two aiming bolts on the back of the assembly , one changes vertical and one changes horizontal. im not sure which one does what tho
endlessrider
Oct 1 2009, 02:59 PM
Thank you very much for the help; I really appreciated it! Happy & Safe Trails and Tracks my friend!
