QUOTE(TRX450RACER174 @ Sep 2 2009, 07:29 PM)
Hey Rick i saw you mention about having split cases if it strips...
Is there no way to get at if remove the right side cover???
Im curios as the dealer overtightened mine when they did the starter update
and i chased the threads on the bolt but it was a lil tough going back in.
I though of getting a long tap to run into it clean up the threads.
Any thoughts on that???
no there is NO other way lol, my buddy stripped his 07 after a torn seal got lodged in the drain hole (seperate issue)
tried to do it from the outside of the right case but no luck, so motor had to be pulled and we had to split the cases to heli-coil the threads
i inspected and inspected and could see no other way of fixing it so be careful is all i can say!! if there is 1 bolt on the quad i would always tighten with a torque wrench this would be it!!!
