QUOTE(want2bfast @ Aug 31 2009, 01:45 PM)
QUOTE(450Rider707 @ Aug 31 2009, 09:45 AM)
Jets are jets, doesn't matter who you buy them from. No one Jet kit is goign to make your fourwheeler any better than the other, the key is getting the correct size in there. They're all the same...
Just note that when buying Kehein jets, their sizes run different than Dyno Jets jets. I stay away from the Dyno Jet stuff because its just confusing.
If you want to buy a jet kit go ahead, its nice to have a bag full of jets.
Dyno jet kits dont work well w/ the 06 newer quads..
NOT all jet kits are the same.. Most have their own style of needle which makes a quite a bit of difference.
Agreed, but they're all usually Kehein Jets just repackaged with someone elses name on it. Or in some cases the Dyno jet jet's just repackaged. You can order whatever needle you want from anywhere, no need to really buy an entire jet kit.
Also who says that's the needle you'll need anyways... no one can really tell you over the net which jetting or needles you need to use, its just ballpark guesses on our end and then the OP will have to do the fine tuning himself, or pay to have it dyno tuned.
Whats wrong with the DJ jets in the 06's? Thanks.
