I'm almost certain it's internals are stock it does have a Yosh Carbon pipe.
Yes it holds a good idle, but I would guess it is up around 2000-2500 rpms
It starts only when bumped over and will NOT start off the magic button, even if the motor is warmed up.
Again it runs great when it is running, this is whats throwing me for a loop.
Thanks again for the help.
QUOTE(gocartone @ Aug 25 2009, 11:57 PM)
Stock quad? Will it idle fine with it turned up? How high do you have to turn it up? Does it start easier then as well? Maybe your just turning the idle down to low for the machine? No running problems at all other then that correct no backfiring or bogging?
