d_eddy425
Aug 19 2009, 03:34 PM
i am new to the forums so im sorry if someone has already answered this question, i bought a 2004 450 r and it seems to have a throttle problem like its hitting a rev limiter, it has a parking brake block off on it and someone told me this could be the problem does anyone know if there is a wire that could of come lose or point me in the general direction of where to start. this is my first fourstroke ive always had 2strokes but my buddies said less maint. on a fourstroke but this one has kinda been a pain in the a$$ since day 1 im not sure of the mods on in i know it has k&n filter yoshimura pipe but im not sure of engine mods PLEASE HELP!!! i am lost and dont know where to start
want2bfast
Aug 19 2009, 03:55 PM
You need to find out your mods.
Exhuast, air box lid on or off.
Check you jetting let us know what is in your carb and go from there.
Hoser
Aug 19 2009, 03:58 PM
It is very unlikely that it is electrically related, if it was, it more than likely would not run at all.
Whoever told you that the parking brake block-off is the problem should no longer be your friend, and you should probably cut off all communication with them. LOL
If your jetting is to rich it will give a "false rev limiter". What size jet is in it?
duner450r
Aug 20 2009, 07:36 PM
less maint on a 4st vs a 2 st???!!! i wish that were true. engine oil and filter to change regularly...valves to check and adjust regularly...
these things do have a rev limiter. are you sure you are not just hitting it? if you are sure you are not, and it really is a problem, start checking the same things that you would on your 2st. spark plug ok? jetting ok? when it does this, what does it feel like? does it rev up then seem to fall on its face? this could mean lean jetting. does it rev than get real choky and blubbery sounding? this could mean to rich jetting.
like stated earlier...check all mods, and jetting...post it up here
xc1993
Aug 20 2009, 08:42 PM
ig chek your main jet i bet your too rich
blackbullet
Aug 21 2009, 08:28 AM
You might be to rich and giving a false rev limiter. The 4 strokes dont rev as high as your 2 strokes you are use to. Also need to check and see if your rev limiter has been removed. Need to take off your head cover and there will be a flapper gear in there you need to take off. Do a search for FLAPPER should find a how to.
duner450r
Aug 21 2009, 06:29 PM
"Also need to check and see if your rev limiter has been removed. Need to take off your head cover and there will be a flapper gear in there you need to take off."
pardon me, but wth are you taking about here? the rev limiter is electronic, not a physical device that can be removed. its programmed into the ignition boxes. never in all my live have i ever heard of a "flapper gear"
blackbullet
Aug 22 2009, 09:56 PM
QUOTE(duner450r @ Aug 21 2009, 06:29 PM)
really no Sh!t. just messing with the kid. Glade you know when somebody is kidding.
jkulysses
Aug 22 2009, 10:06 PM
QUOTE(blackbullet @ Aug 22 2009, 07:56 PM)
To be fair I thought you were serious too lol. I read your post like four times and everytime I was like what the fu*k is this dude talking about lol. That was a good one though haha
duner450r
Aug 22 2009, 10:26 PM
ok...my bad. i didnt want to seem like i was busting your chops there or anything.....
after i posted, i thought to myself you had to be kidding around, no body could possibly believe in a "flapper gear"
