So my front end is a bizniggle. It squeaks, a bent tie rod and on the other side a bad bearing. I ordered the tie rod, and about to order a new a arm and bearings. Oh I forgot to mention the bent hub lol. I am leaving work in 17 min lol and its gonna get a wash and taken apart. I assume I could just clean and grease the bearings and that should be good unless obviously any are broken or bad. Is there a certain grease I should use?
Also besides the basic maintenance like engine/ tranny oil, all fluids, chain tension, brake pads what are some other things you guys do? I am trying to make this quad last~!
Thanks guys
