Full Version: Turbo Charging again
Honda TRX450R Forums: Honda TRX 450R Forum > General Discussion > TRX450R.org Project Quads
kansas450
alright guys i have a turbo on my 450 and i have been fooling with a blow through system trying to make it work and i have just had nothing but trouble with it....We have decided to change our corse and try to make it a pull through system where we suck through the carb has anyone any experience with this or can anyone give me any kind of help or ideas of how it should work?
power junkie
Aw man dont give up on the blow through it is far superior to a draw through setup feel free to pm me with questions mine functions very well.
kansas450
QUOTE(power junkie @ Aug 12 2009, 10:44 PM) *
haha alright well we dont know what else to do i cant get the damn carb to seal i keep flooding the bike when im trying to start it..the pump is a lil big and the regulator is turned all the way down and i think its still getting to much fuel and pushin it through the carb and flooding the bike and then it leaks past the rings and into my oil so i have to drain the oil n start it over and we just keep doing that...
FiftyRider
I am working on a draw through setup right now, but its for a supercharged 450R
boosted3g
Are you guys having any problems with the floats and pressure when running a blow through. How much pressure can you run with a stock carb or a common upgrade like an fcr?
power junkie
There are no problems when setup properly. I run 1.5 psi base fuel pressure and run 22psi boost for a total fuel pressure of 23.5 psi. FCR carbs are great in a blowthrough application.They have no needle and seat or float issues even with a stock size needle and seat. The only issue i have seen is when jumping they will flood on a hard landing so i dont recommend a turbo for jumping but that isnt their intended application, drag racing is.
kansas450
QUOTE(power junkie @ Aug 13 2009, 09:03 PM) *
alright i finally have it running it sounds awsome...i was wondering if you could tell me what jet sizes you are running?
power junkie
Tell me your combination if you stuck with the blowthrough or went drawthrough and give me all the details and i will see if i can give you jet specs based on your combination.
kansas450
QUOTE(power junkie @ Aug 23 2009, 03:23 PM) *
well i stuck with the blowthrough and im running about 2lbs of boost right now starting off...here is the deal is start and idles perfect we are just trying to get the jet set...another question is i put all this on a 2005 and its a kickstart so how would have your pump wired in so it will run? right now i have it ran into my headlights but it acts like its pulling to much juice when i do that..
