mytecgopop
Aug 11 2009, 05:37 PM
for some reason my stock 07 450r is choking up when i give it full throttle.. people said its because my carb is not cleaned and i need to clean it... is there any other reasons why this is happening?
Scro
Aug 12 2009, 10:52 AM
Have you changed anything with the intake or exhaust, like removing the lid or spark arrestor?
zax450
Aug 12 2009, 12:35 PM
did this just start out of nowhere? maybe last time you got gas?
Henner
Aug 12 2009, 04:05 PM
Mine did the same last night i put it in storage for a month while i was moving and last night got it out and it started right up and i drove out the drive way and went to hammer on it and it fell on its face the first 4 or 5 times then it stopped and ran like a charm. So i guess just sitting a month it had to blow some junk out the carbs.. JMO dunno what else would have made it do that.
kyledeitrch
Aug 13 2009, 09:14 PM
QUOTE(Scro @ Aug 12 2009, 11:52 AM)
if u did then u need to rejet is wat hes getting at. and it mite just be junk in the carb
roadsqueegy95
Sep 21 2009, 07:13 PM
kinda bring this back from the dead, but would just replacing the stock air filter with a K&N cause this? cuz mines does the same thing. and thats all ive done to it
kyledeitrch
Sep 21 2009, 07:36 PM
possibly. nothing noticable though.(i would think) the k&n's get a little more air.
roadsqueegy95
Sep 21 2009, 08:13 PM
im wondering if rejetting it might fix it? cuz even just at idle if u full throttle it, but the time u get to about 1/4-3/8 throttle its trying to die, and ive noticed when riding if im coasting and then full throttle it, it chokes for a second before taking off
Scro
Sep 22 2009, 01:52 PM
The FCR's have a bog just off idle. It's just the way they are. Simply changing to a K&N won't cause that much of a difference in air/fuel mixture, so I'm guessing it's just the notorious bog.
zax450
Sep 22 2009, 04:20 PM
QUOTE(Scro @ Sep 22 2009, 02:52 PM)
not to bash on you or talk back but, my FCR does not bog at all. you just have to throw in a dif leak jet and the problem goes away. but if his bike just started doing this out of nowhere we will know it's not the FCR bog.
roadsqueegy95
Sep 22 2009, 04:39 PM
i beleive mine has always done it, from the day i brought it home from the show room. i just never realy worried aobut if because i never rode it much. but now that my gfs got a quad and we go riding with her family alot, its getting VERY annoying. so its a common thing then?
zax450
Sep 23 2009, 10:39 AM
i think the best bet would be to just buy the HRC jet kit and go with it. then you will be jetted properly and you will get the leak jet that is needed to solve most FCR bogs
