dracnik
Aug 10 2009, 04:03 PM
I was wondering if it is possible to get front wheels that are off-set to make the front wider? I am thinking abouit Baja wheels.
Thanks!
Scro
Aug 10 2009, 04:25 PM
Yes, 3:2 wheels will make it about an inch wider over stock. But, the trade-off is you will get more feedback through the bars than you would with 4:1 wheels.
450Rider707
Aug 10 2009, 04:48 PM
QUOTE(Scro @ Aug 10 2009, 05:25 PM)
3:2 is the closest to stock and wont change much at all. 2:3 will really widen it, but like SCRO said, it makes the handling worse.
D Bergstrom
Aug 10 2009, 11:56 PM
Scro has it right. Stock wheels are 4:1.5 offset. So 3:2 wheels would widen the quad about a inch, while 4:1 wheels would narrow it a inch. I would not use a 2:3 wheel, to much feedback through the bars. 4:1 wheels are the best, but a 3:2 wheels is not to bad. If I was looking for a cheap way to widen the quad a little, I would use a 3:2 wheel.
Doug
450RRR
Aug 11 2009, 09:56 AM
the most common Douglas .125 front wheel is a 10X5 and comes with 3:2 offset.....would add a little bit of width to the front with only minor steering issues.......
if your racing on a track....this is about as 'OFFSET' as I would go to compensate.... otherwise purchase +/plus A-arms..
however...if your just a weekend warrior.....especially if your a duner... you can go just about as wide as you would like...
Personally....I have two front wheel dune offsets.... both are 10X6 Douglas wheels..... one is 3:3 and the other is 2:4..
both work very well and in the DUNES, you can get away with this..... although heavy jumping on the 2:4 set is not recommended.....but neither of mine have ever bent..... and yes, it makes the quad very wide/stable....
jmho.....Greg
450Rider707
Aug 11 2009, 06:02 PM
I've rode on 2:3 in the dunes on a buddies bike and I absolutely hated it. However I'm the type of guy to look for these things, as suspension and steering is my favorite past time. I could tell the difference, but I was looking for it.
