Full Version: Shock Service questions
Honda TRX450R Forums: Honda TRX 450R Forum > TRX450R.ORG Sponsors - If you are interested in becoming a supporting vendor, please email sales@atv.com > JET MOTORSPORTS - SUSPENSION SPECIALISTS
Nick @ JET Suspension
What do we do during a shock service?
After years of servicing Late Model Stock car shocks and learning from Indy car shock builders, we are second to none in our service and I realize that is a bold statement, but one we back up. We treat your shocks as if they were our own.
Why do I state all this, because there is more to servicing then just wiping it out and changing the oil.
1. Disassemble and complete inspection, which includes all external components
2. Clean everything internally, not just spraying out with brake cleaner.
3. Inspect internal surfaces for problems
4. Re-lube rebound adjuster meter
5. use special lube for floating piston seals and bladders to reduce scraping
6. Clean each shim in both stacks
7. Thorough bleeding during assembly, including through the adjusters
8. Polish piston rod
9. Obviously, recharge
10. Call you with any issues that will affect the price before we address them, so your not blind-sided by a high bill.
11. Provide setup information and tips on your shocks.
12. We use only the best Synthetic oils.
We look forward to helping you win and hope you chose us for your suspension, you won't be disappointed.
We service nearly all brands serving ATV, Dirt Bikes, Open Wheel and Stock cars. We also service many Steering Dampers.
Service and Parts in stock for;
Custom Axis - Pro Airs as well, Penske, Ohlins, Fox as well as Float Evols, PEP, Exit 2, Works, Showa, KYB, Motowoz, Stadiums, Noleen, etc..
