dsconant
Aug 2 2009, 03:26 PM
What would be the best fix for a leaking brake line bolt of the front caliper? Im stuck with barely any front brakes.
jgardone
Sep 24 2009, 08:18 PM
if its leaking right arond the head of he bolt where it holds the line down some new brass crush washers should do the trick. make sure to check the lines to make sure they are not tore or cracked. and dont forget to bleed your brakes when ur done
