Full Version: chain rubbing on stock case saver
Wags
Just like the title says didnt notice that the stock one did that its just touching at the bottom right above the shift shaft.
running stock gears by the way .
Scro
An aftermarket casesaver would cure that. The stock one isn't going to protect anything anyway. The only thing it's good for is ripping the mounts out of the case.
Wags
I was planning on ordering one but it will not be here by friday going riding.
guess ill just run it like that.
Scro
Take it to someone that has a grinding wheel, or a die grinder. I wouldn't run it like that.
Wags
Well I am a moron I had it upside down dont ask me how .
what kind of case saver are you running ? I was looking at two different tm ones
I was going to go with the one that goes over the sprocket shaft .
Ill have to do a search i remember someone had a pic of one that even went over the shifter shaft.
thanks for the help.
Scro
I wouldn't run anything but the Moose. It's a poly that is formed exactly to the case, and wraps around the shift shaft.
TRX450RACER174
I run the UPP poly case saver.
Wags
Anybody got any pics of these case savers i think i have seen the upp one. Ill have to look into both of those.
