QUOTE(JAKE YATES @ Nov 25 2009, 12:16 PM)
QUOTE(FAST BOY @ Jul 15 2009, 11:59 AM)
CAN ANY ONE HELP CAN YOU FIT AN 05 ENGINE IN TO AN 06 ROLLING FRAME WE HAVE A SPARE 05 ENDURO ENGINE AND WANT TO CHANGE IT FOR AN 06 RACE ENGINE THAT IS FULLY TUNED WE DO NOT WANT TO BLOW HER WHEN DOING THE WESTON BEACH RACE IN THE UK AT THE END OF THE SEASON
WHAT ARE THE PITFALLS AND CAN IT BE DONE WITHOUT CHOPPING EITHER THE FRAME OR THE ENGINE
From what i have seen you just have to use the 05 motor mounts with it.
it wil work the bottom and front lower mounts line up. but always start by putting in swingarm bolt then the rest of them , My mx quad is done this way ,the upper mount i had to shorten the stock 06 mounts took all of fifteen minutes lil plasma cut, lil weld ,i used an 04-5 wire harness as well ,but the 06 carburetor is the way togo. hope that helps
