So the directions say
1. the kill switch should NOT be directly wired to the vehicles on/off switch.
2. one wire from the kill switch will go to a frame ground, the other kill switch wire will splice into the wire between the STATOR and the IGNITION COIL. The goal is to ground the stator wire to shut the engine off.
I've looked in the service manual and I've found the ignition coil and I kind of know where the stator is... it's the SPLICING of the wires that is holding me back.. I would hate to start splicing into wires that don't need to be cut, and I know this has to be super easy..
I looked how they did it on my 450R and it is no where near the stator or the ignition thingy.. LOL
So if you have done this before or can tell from the pics, help a guy out please .. THANKS
