So here is the deal I just installed a Hinson clutch basket, Hinson inner hub, and Trinity plates & fibers & springs. I went to my local Honda dealer to ask how to adjust my clutch from the lever and the lower adjustment. It was simple and the lever feels great, there is a little play, not to much and the lever is firm. When the bike is in gear and the clutch is in @ high rpms the bike rocks forward just a lil bit.....whats going on. I dont think it is the adjustment, could it be the inner hub nut is to tight? could it be the pressure plate sticking? does anybody have any suggestions?
Also after 1st ride I drained the trany side and it was milky, I must have gotten some coolant in. Is that normal? I checked my coolant in the radiator and the resevor, there both full so its not leaking, or at least anymore. I will ride it again and determine if i need a new water pump seal.
2006 TRX 450
K & N
Stock Muffler with baffle stripped out ( Untill Full system )
Carbs Jetted
Pro - Taper bars
Lonestar dual row axle carrier
ITP Series 6 Wheels polished w/ XCR Tires
