QUOTE(Diesel450R @ Jun 20 2009, 10:33 PM)
I was reading through the owners manual on my 08 and it has very specific instructions about changing the plug. Not to tighten it too much or too little as it will cause damage both ways. Can anyone give me some suggestions on how they do theres? I want to make sure I dont damage anything.
just tighten the new plug down enough when it hits the bottom of the threads.
Honestly there is only one way to learn this sort of craft. . . and that is to do it.
do you have any buddies that work on there own machines that you could ask for assistance?
you basically want to inspect the new plug to make sure it is in good shape. . . . .and then gap it. . . .then screw it in till you run out of thread. then just put your socket wrench on it and tighten it down a 1/4 turn or so. .
if it is too loose you can always retighten it. . .. if its too tight and you ruin the threads well .. . . . your in for some bigger problems.
good luck to you. . . . .
Chris
