EricJD450er
Jun 20 2009, 11:35 AM
Hi, any help is appreciated. I have a 2007 trx450er.My mods are as follows:
Rossier Full system, Uni filter, Crf cam, and open airbox.
I have a 168 main, 50 pilot and 2 1/2 turns out on the fuel screw. This was for my spraks system and now Im adding the cam. Im at about 1000-1500 feet.
Am I going to have to change anything?
jimmy450r
Jun 20 2009, 12:24 PM
well in my head your not adding more air like uni, intake, or exhaust would
so the cam shouldnt change the jetting, its just going to open bigger and longer to let more of the same mixture into the cylinder for the bang
EricJD450er
Jun 20 2009, 12:47 PM
QUOTE(jimmy450r @ Jun 20 2009, 01:24 PM)
Ok.. and I just switched from a Sparks full system to the Rossier. Do I need to rejet for that or am I just going to have to try it.
jimmy450r
Jun 21 2009, 06:41 AM
only way to get it nuts on would be on a dyno with an a/f meter (to get every pinch of performance available)
but you should be close, its better to be rich than lean
if its rich you just lose a small bit of performance, if its too lean you can burn holes in piston
I would say 162-175 would be good depending on your elevation
EricJD450er
Jun 21 2009, 08:28 PM
QUOTE(jimmy450r @ Jun 21 2009, 07:41 AM)
Alright man cool. Im at like 1000-1500 ft. So I think I'll try whats in it now. Thanks
JOE@Rossier
Jun 22 2009, 09:01 AM
What needle are you using? Your jetting should be 45 pilot 2 turn out on the fuel screw, HRC needle or CRF needle 4th clip position, and a 160 main. Jetting specs are with the pipe instructions that come with the pipe or can be found on our website.
Thanks Joe
EricJD450er
Jun 22 2009, 02:19 PM
Thanks Joe. Im using the Hrc needle. And I bought the pipe used so I didnt get any instructions. And Those jetting instructions will be accurate for 1000-1500 ft?
JOE@Rossier
Jun 23 2009, 08:33 AM
QUOTE(EricJD450er @ Jun 22 2009, 02:19 PM)
Yes, if you were @ 0-750 than a 48 pilot would work better.
EricJD450er
Jun 23 2009, 03:35 PM
QUOTE(JOE@Rossier @ Jun 23 2009, 09:33 AM)
Alright Joe thanks. Im gonna try it out this weekend. If i have any problems I'll let you know. And I absolutely love the looks of the pipe and cant wait to get one of those end caps!
EricJD450er
Jun 27 2009, 08:24 PM
Just to inform any one. My jetting is spot on with no studders or bogs. Mods are Rossier Full pipe, No airbox lid and Uni filter. Year 2007. Elevation 1000-1500.
MJ: 168
Pj:45
Hrc Needle: 4th slot
Leak Jet: 55
