After further discussion in regards to the rule changes in the Shooters class with FSA race participants. FSA has concluded that it is in the best interest of our racers to maintain the current 2009 rules which will be in effect for both races at "Sandfest 2009" and the 2010 season.
* Under 650 Shooters Class – OEM chassis, OEM modified motors running on approved FSA gas, working front/rear brakes, in frame exhaust system with baffled silencer, 56.5" wheelbase, 505 lb. minimum combined weight, light weight parts allowed, no overriden transmissions, front nose/plastic required.
* Over 650 Shooters Class – OEM chassis, OEM modified motors running on approved FSA gas, working front/rear brakes, in frame exhaust system with baffled silencer, 58.5" wheelbase, 550 lb. minimum combined weight, light weight parts allowed, no overriden transmissions, front nose/plastic required.
