Full Version: jd swingarm install
Honda TRX450R Forums: Honda TRX 450R Forum > TRX450R.ORG Sponsors - If you are interested in becoming a supporting vendor, please email sales@atv.com > JD Performance
blackdrag450r
i noticed a previous thread where you said i have to trim the front chain slider with a knife to get it to fit right but i pretty muched trimmed it alot and it is still a lil' crooked on top and way crooked on the bottom....
is it ok to run like this or is there something i'm missing??
thanks
blackdrag450r
also, the stock skid plate does not fit....
the sprocket rubs on the slider when i try to mount it...
do aftermarket skid plates fit better??
Lonnie
Im running the stock skid on mine and as for the chain slider just get it the bast you can. I got mine pretty straight just took a lot of shaving and fitting.
double d
for your skid plate problem, you either are running a larger sprocket in the rear, or it has been bent, and you need to pry it back down, or put spacers between the skid and swingarm.
