The z-Start Pro offers unique benefits as a high-end complement to Rekluse industry-leading z-Start Clutch. The z-Start Pro offers features which directly benefit pro-level riders, motocross riders, and any ATV rider looking for the highest level of clutch performance, including:
* Perfect override through the entire RPM range
* Smoother engagement with more consistent clamping force
* Billet aluminum center clutch maximizes clutch performance and increases durability
* Simple installation without mounting shims
* Minimal maintenance required
The Rekluse z-Start Pro Clutch is an automatic clutch that simply replaces your stock pressure plate. Control the bike by simply turning the throttle. The z-Start Pro Clutch eliminates stalling, improves traction, reduces arm pump, improves starts, increases corner speed, and puts more power to the ground in the most demanding situations. Whether you're a beginning trail rider or experienced off-road competitor, you can benefit from the industry-leading z-Start Clutch.
ATV Parts - Rekluse
Enter: kbmship at the checkout area to receive free shipping to the lower 48 states.
