Full Version: Lonestar Racing A-Arms
04KS450R
was just wondering if this could be done. I have been looking and cant find any kind of literature on this. Also if it cant be done where do i aftermarket ball joints stronger than the ones from lonestar cause as you can see i made short work of this one.
JH Racing
The are look like Burgard not LSR. Check and see if the balljoints are 16mm or 18mm
04KS450R
where do you look to find if they are 16mm or 18mm ? or if they are LSR or burgard
double d
QUOTE(04KS450R @ Jun 8 2009, 02:47 PM) *
if a 14mm wrench fits over the shaft, they are 14mm. if not, they are 16. Heims will fill up w/dirt and will grind apart in no time (not worth it)
04KS450R
can ball joints be bought from like parts unlimited or tucker rocky ??
double d
QUOTE(04KS450R @ Jun 9 2009, 02:22 PM) *
Those are 14mm, you can get them from a VW supplier, they are for any year transporter (bus) RH threded tierod end (not a bug), however, they wont have plating and will start to rust the 1st time they get wet. JD Performance also sells them as a replacement for burgard,and older Laeger and JD arms ( plus they are plated ($24.95 ea)
Dave
Jd Perf
951-676-7957
450rSickness
I have LSR a arms that are three months old and my lower ball joints are shot..... does anyone know where I can get replacement ball joints without having to go to lsr and spending $120 on them and having them go bad in three months again? They are 16mm by 1.5
samm3020
Hey if you guys are looking for 16mm ball joints i can get them for like 20 a piece plus what ever shipping is.
ratracing99
QUOTE(samm3020 @ Sep 26 2009, 12:28 AM) *
Go to Shucks or Oreilly autoparts online and order PN# ES3045R they are the M16x1.5 ball joints that lonestar uses
lwrider20
QUOTE(ratracing99 @ Oct 12 2009, 02:39 AM) *
same size balljoint but no the same balljoint.
ridinredodb
QUOTE(JH Racing @ Jun 8 2009, 09:40 AM) *
yeah my exact same thought. i have burgard +2 a-arms identical to those and they are junk thats why i bought JD performance +2 a-arms to replace them
450rSickness
QUOTE(lwrider20 @ Oct 12 2009, 11:42 AM) *
Hey thanks alot guys and these will fit??? I know my lsr have frap ball joints #2444 thumbdown.gif
