Full Version: My 07 trx450r
want2bfast
This is my stock/bore/stroke.
RE head
DASA Pipe
ESR intake
Click to view attachment
Second to the end..
QUIKSHRK
want2bfast
QUOTE(QUIKSHRK @ May 26 2009, 03:41 PM) *
Ya I did that on purpose. check this one out.
miller450r
thanks or sharing, are you wanting to tell any more details ? cam? stock piston? pump gas?
all stock valves?
want2bfast
QUOTE(miller450r @ May 26 2009, 04:06 PM) *
all stock valves?
let the dyno bashing begin.
208 cam
+1 ex valves
sparks piston 15.1
sunnoco(sp) 110
miller450r
i certainly hope it does not...dyno's can all read so different, and I thank you for sharing again and for taking the time to show a straight up graph and take the heat if it comes your way...
Speedbump
Amir is awesome, his wife is a crack up. Some of the nicest people I have met that own and operate an ATV shop on the Coast.
Amirs dyno reads fairly normal and in line with others I have been on.
Kip
From what i have seen/heard. His STD numbers are in line with Cams SAE numbers. And Cams STD numbers are in line with RE and most of the "Industry Standard" dynos.
Nevertheless, great build! Ill bet it could pump out almost 60/34 on other dynos.
-Kip
blackdrag450r
gen 1 head??
btw, where did you get that "HONDA" sticker?? it looks good!
want2bfast
QUOTE(blackdrag450r @ May 26 2009, 05:06 PM) *
gen 1 head??
yes. Gen 1
Icecream
QUOTE(want2bfast @ May 26 2009, 07:08 PM) *
all stock valves?
208 cam
+1 ex valves
sparks piston 15.1
sunnoco(sp) 110
looks about right for a dyno jet
true numbers
good running bike
elf
Nice graph Rob.
mwsartain
Great build Rob!
Congratulations.
want2bfast
My 06 was pushing 55hp on a superflow. So I would guess this is pushing quite abit more. So numbers dont mean everything. When I want throttle it is there. My 06 is the bike on the end w/ a 30lb lighter rider and a +3 swinger vs this one is stock.
rebel
QUOTE(want2bfast @ May 27 2009, 07:56 AM) *
Great build Rob. Its good to see that you got youre build done before the fury. Look to me in the vid that you just about blew the tires off the wheels on the launch. i bet with a little pressure adjustment that thing will launch like a rocket with the stock swingarm. Youre roost was alot higher then the other racers. Were are you staying for the fury.
rebel
Rob how do you like your dasa pipe?
want2bfast
QUOTE(rebel @ Jun 4 2009, 07:03 PM) *
it is loud but it made like 1hp more than my hmf dammit...
want2bfast
QUOTE(rebel @ Jun 4 2009, 06:58 PM) *
If I go I will be hanging w/ elf.
cody fuller
QUOTE(want2bfast @ Jun 4 2009, 09:38 PM) *
i just switched from a hmf ironman to a dasa,, but i have yet to put it on, hope it was worth it
HeavyHitter
lookin good rob. When did you go down to the dunes? I thought your black bike was still torn apart? Mine is running awesome.
want2bfast
Dude check the date on this...
