QUOTE(RIDE RED @ May 18 2009, 01:19 PM)
QUOTE(DOZER520 @ May 18 2009, 09:13 AM)
QUOTE(mcioletti @ May 15 2009, 03:05 PM)
QUOTE(bueller @ May 14 2009, 08:54 PM)
QUOTE(RIDE RED @ May 14 2009, 04:23 PM)
According to the post on piston weights in the eng section the stock piston weighs 457 grams & the Venom piston weighs 377 grams.(80 grams lighter).Wouldn't that cause a balance problem???
I ran that same piston in my 05 and never had a problem or felt it needed to be balanced. You'll be fine.
80g is a big difference, if money is an issue get it balanced with a new piston and hold off on the port and polish. You will get alot more life and a little more power out of an engine that is balanced and save money in the long run.
You can't feel if a single cylinder is out of balance BTW.
try running an unbalanced 501 build for a day and tell me if you can feel if a single cylinder motor is out of balance
mixxer has stated in the past that when you have a piston that is lighter like this case it is much better than if it is heavier. the piston is what is starting and stopping several thousand times a minute. it's always better to be lighter, will be less resistance.
So if the piston is lighter I dont need to have the crank balanced????
Well I hear that nitrous is better so I'm gonna put it on and do no other mods. does this sound right???
OK so if someone were to build a 501 from parts and not balance it the effects would be obvious, unfortunately this isn't what we are discussing here.
Replacing a piston with a lighter one won't feel much different because your crank is taking the beating.
when these bikes were made the crank and piston are made as an Assembly. the heavy piston's accelerating up and down is creating forces and the crank is throwing it's weight around creating forces to counteract those made by the piston, making the engine somewhat balanced.
Now throw a lighter piston in and you reduce the forces that the piston exerts on the crankshaft (yes the lighter piston is creating less force on the crank allowing the engine to rev quicker) The crank is still throwing the same weight around but now has less weight from the piston (80g less in this case) to counter act the forces it is creating. This will not be felt by the rider, but your crank is absorbing this imbalance up to 10,000 times a minute. 80g seems small but at high speeds it creates high loads.
Everyone wants easy power, swapping a piston for a lighter on is easy power and a shortcut.
An unbalanced engine will be a liability and have less power.
You want your machine to rev quick? light piston helps, balancing the crank will make it lighter and rev quicker.
I have never heard of an engine builder who thinks you can change piston weight and not balance an engine.
Don't believe me? try reading a book. I know a good one, it's called Design of machinery: an introduction to the synthesis and analysis of mechanisms and machines , I took the class in college and know the book well. this is a pretty basic approach anyone technical can understand
heres the link to a google books preview
http://books.google.com/books?id=iepqRRbTx...ncing#PPA674,M1everyone wonders how engines builders are so good, it's not an art it's math pure and simple. books like these will learn you on engine dynamics ( I have more references if anyone wants more).
Have an understanding of what you are talking about before you go posting what you read on the net and have no real knowledge of.
Balance your crank with a new piston and write the weight down, your next one will need to be adjusted. It will save you money and headaches in the long run as well as maximize power.
Engine balancing is grossly overlooked, many of the sob stories of engines blowing up would not be if it were for properly balanced engines.
take your eyes off the dyno charts for a min. and think about the day ruined by you motor blowing up. 60HP is no good if the engine lasts 20 hours
