Full Version: some questions.. about er wont start when in gear holding clutch
mytecgopop
it doesnt wana turn over in gear when im holding the clutch any ideas? and also where do u put the brake fuild in i think im low.. and under the hood thats where the anti freeze goes right?
want2bfast
check the connections by the clutch handle. Or just wire them together.
Brake fluid for front brakes go in the Reservoir for the front brake handle.
The rear brake Reservoir is on the right side of the sub frame.
450rlou48
You need to start it in neutral. That is just the nature of the beast.
kyledeitrch
QUOTE(450rlou48 @ May 13 2009, 06:41 PM) *
haha true and yes under the hood is your anti freeze but dont fill it too high because it will over flow
ted_bell
Your starter is probably trying to move the whole bike. Adjust the clutch lever so that it disengages the clutch. I start mine in gear all the time.
Scro
Twist the wires coming out of the perch together if it doesn't turn over at all. If it turns over, but doesn't crank, adjust your clutch.
