It is on a Lawnpro carcass, and is pretty light, but the profile is very flat and wide. Take a look at these and tell me what you think.
The rollout says 70 on the tire, i havent measured them yet.
My problem is, even with 12/38 Gearing, these paddles with 5lbs of air, preload on shock all the way up, or rings all the way down, and my 140 lbs on the tank, it will NOT launch in second. Just bogs and goes. This is in pretty heavy Oregon sand.
The tires are on 8x8 rims, do you guys think i would benefit from putting these on an 8x6 or 8x7 rim?
I want them a little bit rounder, but i want to be able to launch in second so i can dune this bike. 15/38 gearing is worthless for the duning i do.
I do not have the clutch mod, does anyone think this would help?
When i launch, i tap it and dump the clutch, should i be trying the feather technique out of the hole?
Thanks!
-Kip
