QUOTE(556KingR @ Nov 1 2009, 07:07 AM)
Mr. Torque,
I have to respectfully disagree at least on the tire size making a power difference on an inertia dyno. I tried two drastically different sized dyno tires on a dyno jet and they were absolutely identical to each other. At least in RPM. I never looked at it in speed as we never do so I could'nt say for sure on that.
I dont know about gear changing resulting in differnt readings. I never tried changing gearing on the dyno. I thought that would also yeild no difference, again at least in RPM.
King, I had this debate with an honest to God dyno Guru quite some time ago. Here is a statement that came from one of the top tuners in the country that has tuned thousands of fast cars and bikes, and he tunes on both types. Heres what he said.....
Inertia/accelerometer style dynos measure the acceleration rate over time (point A to point B). If you change the numerical "gear" you test the vehicle in then you will change the acceleration rate of the vehicle and the "Calculated HP" due to manipulating the amount of torque output available at the wheels.
On a proper dyno that actually measures the torque, it will not. Here is the math....
HP = Tq X RPM divided by 5252
Gear Ratios
1.) Divide RPM
2.) Multiply TQ
Using the formula above.
Example:
An engine produces 100 ft/lbs at 1000 RPM
100 ft/lbs X 1000 RPM = 100000
100000 divided by 5252 = 19 HP
The engine produces 19 HP!
The transmission is in a 3.0:1 gear ratio
100 ft/lbs x 3.0 = 300 ft/lbs at the transmission
1000 divided by 3.0 = 333.33333 RPM
300 ft/lbs X 333.33333 RPM = 99999.99
99999.99 divided by 5252 = 19 HP
19 HP Available at the transmission
The engine still produces 19 HP!
You have a 3.73 final drive (rear end)
300 ft/lbs X 3.73 = 1119 ft/lbs at the rear end
333.33333 divided by 3.73 = 89.36 RPM
1119 ft/lbs X 89.36 RPM = 99999.99
19 HP Available at the final drive
The engines HP never changes, only the torque output and speed thus changing the acceleration rate.
Inertia style dyno = yes the gearing will change the calculated HP
Proper actual measurement dyno = no it will not change the "actual HP"
Now, I dont claim to know it all about inertia style dynos, but im not one to take anyones word for it so I tried it on mine, and there is no HP change. I remember trying it on my drag cars several years ago and his statement definitely holds water on automotive dynos. I have yet to test it on an ATV/MC dyno but i will...soon.
