The majority of text is from .org members Pgreenlaw and 450rr. Please note that the service manual calls for a different procedure with more steps and special Honda tools (though this worked perfectly for me). Please read the disclaimer at the bottom before proceeding.
1). Ensure that you have all the correct parts. The PN for the full kit with new starter gear. starter clutch, roller bearing, and crank nut retainer is Honda PN: 06220-HP1-306. It is around $112-$140. You may be able to get by just replacing the starter clutch itself, but the current bulletin directs dealers to install the full kit to alleviate starter woes. You will need a right side case cover gasket, Honda PN: 11394-HP1-600, which goes for around $17-$23. You will also need a quart/liter of gear oil (or engine oil, whichever you fill your transmission with. I use Honda gear oil), and coolant (if you are careful you can store what you have in your radiator in a clean container and reuse it).
2). Run the bike for 2-3 minutes to warm the trans fluid. Drain coolant and transmission fluid. Drain the coolant at the lower radiator hose, tipping bike towards the pump side to get all the coolant out so it doesn't leak out later. The transmission drain bolt on the 06 and up models is under the drive sprocket behind the shifter. You will need to remove the brake lever which is a single allen bolt at the base of the lever. I found it much easier to work on after removing the header pipe on my yoshi exhaust, which was held on with only two springs.
3). Remove entire right side outer case using the 8mm bolts around the outside. There is no need to remove clutch cover or water pump cover. Keep track of where the bolts go because there are like 4 or 5 different size bolts that must go in different length holes. If you are careful you can leave them in the holes as you remove the cover. As you pull the cover off, two metal tubes (one with an O ring) will probably come off with it. Don't lose these. The long skinny one holds the small gear in right above the starter. The short one with an O ring goes in a recess above the water pump. Go ahead and put them back in their holes so they don't get lost. Thoroughly clean the sealing area, being sure to scrape all the old gasket material off.
