Full Version: Quad boggs when WOT
MotoX_Rider
i have an '08 yfz 450 and when i have the quad WOT it bogs and even sometimes stalls. Even if im in neutral and rev it up it'll most likely stall when i push the throttle all the way in.
Any ideas? I'm afraid of hittin jumps cuz i dont wanna go to hit the throttle and have the damn thing die on me.
I have a full moto RS4 pipe with the lid on if that helps at all
MotoX_Rider
anyone?
Rat-A-Tat Racing
I would say the carb in clogged, check the float Bowl and main jet. What about your Air filter, is it dirty and what mods do you have if any. Got to be something that easy.
hasteranger
I had the same problem everyone told me to change my jetting. Mine was worse when it was cold. I changed my jetting but haven't ridden it since so I can't say if it helped.
MotoX_Rider
i brought it to the dealer and they said that im goin to need some $300 part
want2bfast
go to YFZ central and look up carb mod. You zip tie or o-ring the a lever on the side of the carb where the throttle cable goes. You can also find this on thumper talk. And you may also have to adjust the jetting.
want2bfast
QUOTE(MotoX_Rider @ Mar 30 2009, 06:36 AM) *
Don't buy into this..
MotoX_Rider
i tried puttin up a post in yfz central but they deleted it...WTF...i hate that place, bunch of A holes...
chornet44
go to thumpertalk. ive read something about a carb mod for you yami guys on there.
chornet44
QUOTE(chornet44 @ Mar 30 2009, 03:06 PM) *
but before doing anything id pull the bowl and main jet and check for clogs
MotoX_Rider
QUOTE(chornet44 @ Mar 30 2009, 04:08 PM) *
already did, everything looks good
vcforlife15
QUOTE(MotoX_Rider @ Mar 30 2009, 04:13 PM) *
You let the shop "fix it"?
MotoX_Rider
QUOTE(vcforlife15 @ Apr 4 2009, 02:15 PM) *
no no no, jus look at it. I ordered a new leak jet and installed all that in n now the f'in carb is leaking....UHH yami's blow banghead.gif , good thing nothin goes wrong with my honda thumbup.gif
vcforlife15
QUOTE(MotoX_Rider @ Apr 5 2009, 11:29 AM) *
is your float in complete working order?
MotoX_Rider
yeah, but i think im missing an o-ring piece....
h0nda450mainiac
my buddies 08 450 had the bowl go to crap on him two there pretty weak.
YFZRider69
What are you running for jetting. Sounds like either your needle needs adjusted or you need to go bigger on your main. I have a yfz and mine is jetted just about perfect. Also what needle are you running. The ncvq needle is the most popular.
lilred
DID you get your yammi carb fixed what was the prob?
