1sikR
Mar 2 2009, 09:47 PM
im looking to run this setup now that i have taken my engine apart.do you guys think this is a good setup , i need to change the crank reguardless so the 3mm is staying but not sure on the high comp piston????
rrguy
Mar 2 2009, 10:33 PM
Probably mainly depends on if you want to run race gas, or how available it is. You will be close to 13.5:1 with the stroker. For trail riding & occasional race here & there I would probably keep the comp lower so you can run prem pump gas if needed. just my 2 cents
the 05 hrc cam should work good with that combo. Port work should help stretch your arms a bit more.
That is where mine is now but planning to throw on a bigger bore cylinder & dropping the compression.
1sikR
Mar 2 2009, 10:37 PM
race gas is easy to find down here so that not the issue. I have a hrc cam in it now.
TRX450R14
Mar 3 2009, 11:36 AM
I have been running a very similar setup for 2 years now (HR+3,Wiseco13:1,HRC cam) and it is just awesome.
1sikR
Mar 3 2009, 03:23 PM
what gas are u runnin 110 or c12 112oct??
TRX450R14
Mar 22 2009, 10:09 AM
Sorry...I complete forgot about this thread.I don't run race gas,except when I go to the dragstrip.I trail ride 90% of the time and I just run supreme gas and sometimes throw a tiny bit of octane booster in for good measures.
