I have seen the kits made for around 100 bucks. Great deal for some but I know it can be done a lot cheaper. For $31 and some change I went to the local autoparts store and ordered the smallest tranny/oil cooler I could get. It comes with hose and clamps and the black zip binders for mounting the cooler. This one measures 12"x5.5"x.75". It has 3/8" fittings but used 5/16" hose and you'll see why.
The mounts were the tricky part BUT simple. The upper mount is made with three strips of aluminum, two are bent to a roughly 70 degree angle for the horizontal strip to rivet across where the cooler will mount. They bolt directly to the frame where the two black wire harness clips clip into. Remove them and they expose roughly 1/4" holes to bolt the upper mount to. The bottom is another strip bent to contour the cooler and bolted to the cross piece behind the bumper. I opted to use a felt weather stripping between the mounts and cooler for vibration wear purposes. The kit comes with little foam squares that serve the same purpose.
Once the cooler is mounted, it's time to adapt the oil line system. I disconnected the factory oil line on the right side (oil pressure line from engine) and cut just before the first bend with a small pipe cutter specifically to keep metal chips/shavings out of the system and for a clean cut. Then you'll take the other piece cut off and cut this about 1/4th of the bend from the factory cooler mount. The mount is reinstalled upsidedown so that it bends upward. Because the diameter of these factory lines are smaller than 3/8", I used 5/16" hose that fits very snuggly over. From the engine to the cooler and from the cooler back to the factory cooler and tighten with hose clamps. I started it up and topped off the oil with about an extra 1/8th of a quart.
Thinking mount ideas...
Mounted with the aluminum bracket bolted to the clip holes in the shock cross frame.
Plumbed into the factory oil system. No drilling, taping or any other BS required.
Fit and finished!
