Full Version: my 511 sheet
Hitokiri
its alright but i think its still missing something
sorry for the small pics ill try to resize them differently
jwilson84
cant see it
r450er
cant see.Looks like58 ish?
Hitokiri
here resized
jwilson84
58/34 isnt bad. tq a little low maybe, my 533 made 58/42 different dyno though
Hitokiri
its 58.54hp and 36.98 ft/lbs torque
mwsartain
Nice runs! I bet it's a blast to ride!
hoop52
how's this
Click to view attachment
Cleatus
Those are nice numbers. I can't wait to get mine on the Dyno!!!!
miller450r
thanks for sharing that info!!!!
Raistlin 12
I would have thought it should be just a little higher than that.
hoop52
i think i might take out the stage 3 and get a web 208
Pgreenlaw
Nice numbers. I'm actually hoping for more that that out of my 490.
hoop52
i talked to RE today, they said they'ed like me to bring it to them, they think they can get more out of it. a lot folks say to get rid of the +3 crank. it's just a $$ thing right now. will see what it does with the a 208 web cam.
Morgan
QUOTE(hoop52 @ Feb 16 2009, 09:58 PM) *
Don Im assuming you talked to John, but I would love to get my hands on this motor. Watching it get built and blow up 10 times now is really getting to me.
I can tell by the graph that we can/would get more out of it.
hoop52
back in 07 i had a 470 build stock stroke, 98 mm bore with a venom 14.25 piston. hasd guy here in vegas install new valves (KW) and a port job. that motor seemed to have more punch on the bottom, never had it dynoed so don't know what the # were. I picked up a used cylinder cheap. i might think about going back to a 98mm bore with the venom pistom and stock stroke with the RE head and 208 web.
Kip
I would get the motor to racers edge. I know for a fact there is more in this motor than that.
My stockbore RE build with MILD parts got almost there.
55/33
That should be a 65/40 motor no problem.
-Kip
very_fast_450
the dyno can be humbling to say the least.
Have fun with your build!
depotman
If you don't have anything positive to add to the thread, stay out of it.
ghott
What does a stock bike make on this dyno?
very_fast_450
QUOTE(depotman @ Feb 17 2009, 12:55 PM) *
I hope you were speaking of Jason's posts, and not mine... I get so paranoid around these boards... LOL!
JJONES660
QUOTE(very_fast_450 @ Feb 17 2009, 03:28 PM) *
who me? LOL mine was erased...it was a tad offensive given the scenario and so Im not gona raise a stink over it...
truth be told 58/38 is healthy...I just expected more....and thats where ill leave it...Ive always been very happy with my engine which has had similar outputs so i think if he can look past numbers he will be pretty stoked
hoop52
QUOTE(ghott @ Feb 17 2009, 10:41 AM) *
got no idea. The only comparasion i have is greylnn's was dyno on this machine, then he took it to RE and there was only 1 hp difference.
Morgan
Like we offered, get it to us, I bet all these comments go away. They did for Greylynn.
Cleatus
QUOTE(Morgan @ Feb 17 2009, 10:11 PM) *
That's an offer I wouldn't refuse!!!
Hitokiri
Thanks for the help morgan, I know my dad called you guys and i guess were gonna make the drive in like 3 weeks to see you guys. I just cant see why it wouldnt make over 60 unless the dyno is a little stingy but hey, i guess well find out. Also were gonna get the web cam and see if that makes a diference
Morgan
QUOTE(Hitokiri @ Feb 18 2009, 03:00 AM) *
The 2 dynoes are within a HP of each other. I found many things wrong with Greylynns motor, Id like to take yours apart and see what the deal is.
Hitokiri
Ya i rememberd that when grey has his down there with the 1 hp difference.
I hope you guys dont find much wrong, we replaced alot of parts since the valves droped back in november on turkey day weekend.
greylynn
Take it down there Don, get the kinks sorted out, you won't be disappointed.
Grey
556KingR
QUOTE(greylynn @ Feb 21 2009, 01:58 AM) *
Grey
Hey Grey, the things that Morgan found wrong with your engine, were they because of the last guy who built it? Was'nt it that guy TTG or something like that? He helped you out when the original build blew up right? Just curious.... Hope its running good for you now.
I gotta say, as much as Ive bumped heads with Morgan over there years, I feel like their doing some good work over there. If he's willing to look over the engine Id take him up on it.
Hitokiri
well were leaving tonigh to get to RE az by morning. 7hr drive my dads been talking to them so i dont know exactly whats gonna be done. ive only changed from a hot cam st3 to a web 208 so there will be a difference already but cant wait to see their shop the gallery on the site looks pretty good
hoop52
Well 22 hrs later we're back home. it took us about 7.5 hrs drive each way. Got some good numbers. was at 58/38 on a dyno here in vegas. since that dyno was done, we swapped out the st III cam for a web 208. Grey's bike was run on the same dyno in vegas as mine, then at RE with nothing changed and was 1 hp higher on RE's.
We had a blown head gasket that got changed out, Brett did some tinkering on the head, don't know for sure what all he did, but I do know that they took .005 off the head, cause the head gasket was split and hitting head so they did the decking to clean it up. We did some swapping of intakes, mine and a FCI and my Rossier & Dasa exhaust. We even tried differnt fuels, my torrco 110 and some VP 110.
Ended up keeping my intake and changing exhaust to the Dasa. Will also stay with the Torrco.
Brett, Morgan and John were all Happy (along with us) with the final results. Brett said if I posted the graph, some won't believe it. I don't have the graph with me now, my son has it. I told him he could post it later or maybe Morgan will. I won't even post the numbers now, so you all can take a guess what it might be. But as a lot of folks say, numbers aren't all that important, it's what it does on the hill. but i bet my 6 paddle extremes will have to go and maybe a set of 8 paddle gliders.
As a final note, Thanks to all at Racer's edge. Was glad to meet them all in person and match names to faces. They're all top notch folks, hard working and they don't mind you picking their brains for some info. Thanks Again RE.
We'll be out to dumont next weekend. we're not racing in the FSW, but will be lined up next to them doing some running. we're also going to do a day trip tomorrow at Amargosa dunes to see how it does, and do some gearing swaps. there's a couple of 700+ raptors we're going to see what it'll do TO them.
Kip
Ill bet its around 70/50
Hoop, can you PM me the numbers, i wont be telling anyone.
Racers edge is where its at!!!!!!
-Kip
Hitokiri
Yes i do have the dyno sheet in my possesion. Im not gonna post until sunday or monday til we can get it on the dyno down here just get a comparison just to make sure these dynos are within 1hp of each other still. I left with the power on the dyno sheet on the first page. 58hp 37.96tq
Gonna be at armogasa tomorrow and ill get some vid too but she is gonna run good. i can already tell.
Thanks to Pure Evil Las Vegas for getting the main engine setup done for us with the crank and cylinders, and piston and dyno runs, and getting her back running And for all the deals you guys hooked my dad up with.
Thanks to Racers Edge AZ for the awsome head and help with the fine tuning and advise. we switched exhaust and intake combos so many times and finally found a good one Brett, morgan and john are awsome guys down there and gots all the high tech equipment
ill post RE dyno we did today and pure evil dyno sheet together side by side to see what we gained on his dyno
yfz450admirer
When are you doing the day trip to Amargosa? It was a runner before when I rode it last, I want to see it now.
Hitokiri
went today and it runs freakin awsome. all the guys i usually ride with notice right of the bat this thing is running good.  Im gonna strip her down as much as i can and enter Four stroke wars at dumont this coming up weekend
