Full Version: Hot Cams S1 + S2+ S3 Dyno Comparison....
Pages: 1, 2
mixxer
this season my own TRX will be a pump gas setup with stock valve sizes.....
i've made the most power with high compression and +1 valves in all 4 corners.... and at the prodding of my better half, tress... "i've".... LOL.. decided to see how well things run without the added expense of bigger valves and race fuel compression ratios....
so.... while i was at it on the semi-budget minded build.... i decided to test all 3 available Hot Cams... Stage 1...Stage 2...and Stage 3.... for a good comparison of the power characteristics of those cams on the same bike and on the same dyno , on the same day......
i wish Hot Cams didn't lable the cams as Stages.... it makes it sounds like each step makes the last one insignificant.... when they are actually focused for different uses...
the Stage 1 should be called something like Torque Master or Earth Mover.... LOL.... i use it in my CRF450x Bike... and it feels like the engine has 100cc's more than it does... instant response... almost pre-emptive response....and it pulls like a freight train.... it has to be THE most underrated cam in the industry... for stock displacement machines and Woods to MX riding, nothing pulls off the bottom to mid like this cam does....
the Stage 2 should be called something like Superman...LOL.... because it has no weaknesses... it pulls the broadest power curve ...and no matter what you plan on doing, you wont really have the wrong cam with the Stage 2
the Stage 3.... i have no idea what to call it... it pulls the farthest on top end.... but you have to give up something to get something here....
thanx to site sponsor Paul @ Woodward's Specialties for the killer prices and service on the Hot Cams!!
so...on to the Graphs...
Stage 1... Black Lines:
rules the bottom end with authority until 6600 RPM where the S2 matches it...and the S3 doesn't match it until 8000 RPM... if you "Gun & Run" from exiting lots of corners in your riding type.. this cam pulls brutally strong.... the earliest\ most torque ... and the most roll off after the power peak
Stage 2...Blue Lines:
super wide power curve... not as much early torque as the S1.... not as much in the overrev as the S3... but pretty darn close on both counts...
Stage 3.... Red Lines:
the most peak HP... the most power from peak to the rev limiter... but it also gives up the most bottom end to do it
i tested the cams in this order...S1...S3...S2... since i planned on leaving the S2 in at the end of it all...and wasn't going to loctite the cam bolts in place until the end of the testing....
BUT... i have to say.... i a little bit disappointed that i didn't run the S1 last and leave it in the TRX... i wouldn't take the S1 out of my CRFX for anything....!
remember... you'll have the fastest setup for your riding if you setup the power curve to match your type of riding\use....
hope the graphs help some of you in your cam selection
Click to view attachment
1mtwallet
What a great post!!!!!!!! Excellent work! I just installed an HRC cam in my 07 and I'm very pleased. I've been told that it is very close to the stage 1 cam. Me likey!
scrapper450r
john, awesome comparison. cant beat venom for sharing info. much appreciated.
its hard to make a decision on a cam when you see it that way.
i am going nuts waiting to get to the dyno. 2 1/2 weeks and counting down.
mixxer
QUOTE(1mtwallet @ Feb 15 2009, 07:18 PM) *
correct... the 06 & up HRC cam is very similar to the S1... excellent cam...!
mixxer
as always... you guys are more than welcome for the info.....
Eric
Thanks for that mixxer. Very informative. Very straight forward. Very straight up.
Is there anything like this posted with a stock bore setup? Would you predict the comparisons to be similar in a stockbore/stroke configuration mixxer?
I ran a stage 2 on my basic stock bore build and will be running it on my high comp. worked head build as well. I was toying with the idea of a HC3 but that just went out the door... for now...
Eric
mixxer
QUOTE(Eric @ Feb 15 2009, 07:39 PM) *
Eric
the cams will have largely the same effect on a 450cc powerband.... the differences will be slightly exaggerated with a bigger loss of bottom end on the S3....
conversely...if the engine was bigger yet, the S1 would have more roll off of power on the top end...
450rguyslsd
Thats some pretty close numbers, great info!! I'm putting that stg 3 in stephs this week...
xc1993
im thinkinf about the stg1 now lol thanks for info really cool
556KingR
Whew, lots of time here and we thank you for your efforts and willingnes to openly share your info John.
I like the stage 2 in that group. Like you said though, it depends on what your doing.
I so agree on the naming of the cams. It just makes them sound like stage 1 is better than stock, than stage 2 is better than stage1, and stage 3 is better than everything. It comes down to terrain and riding style.
Id still like to see the stage 1 retarded....no joke. Throw in a handful of degrees and see what happens. It may make you like it over the stage 2, who knows.....
They really did a great job R&D'ing these cams and really getting them to do what they do. Its not like they made one cam and then made the same kinda powerband but just more power....no they made it a point to make power on the bottom to mid, then a spread mid, then a mid to top. Great selection for your riding style.
mixxer
QUOTE(450rguyslsd @ Feb 15 2009, 10:51 PM) *
it's about time, nick!!
mixxer
QUOTE(556KingR @ Feb 16 2009, 06:40 AM) *
you come on over Gar...and you can run the dyno with any amount of cam degreeing change you want!! open invitation.... :)
NHRAdragracer
Pgreenlaw
I had no idea that the 06HRC cam was comparable to the Stage 1. I ran that in my bike for a long time and always felt like it had pretty decent top end pull. Maybe I was giving up a length or two with this cam????
homdaddy
so how do you think my 480 set up would fair if i take the stage 3 out and put the stage 2 in
bw high comp piston
venom ported head
42 fcr carb
and good ole pulse charger
shes only ridden at the dunes
1mtwallet
QUOTE(mixxer @ Feb 15 2009, 07:30 PM) *
Hey do you guys do any street bike machine work? I tossing the idea around of putting a big bore kit in my vtx 1800. It would have to be resleeved to 4 1/8'" from the stock (I think is around 4")
Bling
Yeah wish I would have been armed with this a few months ago. I've got a S3 in my Venom pump gasser 480. It's tremendously faster than it was stock, but I can definately tell it's a little soft down low. I get pulled from a dig by stock bore bikes and have to use every bit of space to reel them in. I'm seriously thinking about switching from this S3 to a S2 after looking at those graphs. If anyone in here has an S2 and wants to try an S3 pm me and we can work something out.
pipejob1
How would you compare the the HRC 04-05 cam to the Hot cams which one.
556KingR
QUOTE(pipejob1 @ Feb 16 2009, 09:09 PM) *
I would have to say its more like the stage 3 than the 1 or 2.
soyo
great information, thanks, jerod
depotman
Great info. Nice layout and easy to read. Thanks for sharing.
I'll take the Stage 2. It gives up nothing to the Stage 3 until around 9k rpm. I think I am going to put it back in over my stage 3.
mixxer
let's see:
nope , i don't do street bikes.... sorry...
my own personal preference in powerbands is the stage 2.... or stage 1 for my CRFx dirt bike....
the 04-05 HRC cam makes more top end and less bottom end than the HC S3....
1mtwallet
QUOTE(mixxer @ Feb 17 2009, 08:58 AM) *
let's see:
Oh well. Still a great post! LOL!
soyo
im usually good at "feeling" any changes in power when i swap something out. i took out a stage 3 and put the 208 in and in a drag race could not tell at all, but on my practice track i did notice a little better throttle response and i also noticed it did come on a little earlier but not much. i think peak is the same with a hair more torque that carries a little longer. but this is my opinion from the "butt dyno"
i have always wondered what they would do on the dyno though. if they are close i dont think it would be worth the money to get the web and then buy springs for minimum results. i was suprised to see the results of this test and have to say stage 2 is pretty good!! very good info thats helped alot of people out, thank you, jerod
HRE
QUOTE(556KingR @ Feb 16 2009, 05:40 AM) *
I agree with this statement 100%. Or, take the Stage 2 and degree it in for more bottom end for those that need it or go the other way to kick the Stage 3's butt.
I thought of this about six months ago when everyone was having a yard sale on Stage II cams cause the Stage III was just released.
Just my opinion.
mixxer
QUOTE(jebbin12 @ Feb 17 2009, 10:33 PM) *
Have you tested the web 208? Any idea how it works its way in there? From what I have heard people say it is pretty close to the stage 3.
there are 2 versions of the 208....
a RBC\ reduced base circle version that has harsh velocities that beat your valvetrain to death for a ~ 1.5 HP gain over the S3
and a FBC... full base circle version that doesn't beat your valvetran to death.... and works about the same as a hot cam stg 2..
miller450r
I have seen dyno's from a high 50's stockbore comparing the FBC and RBC 208 and the Stage 3. The stage 3 hands down comes on the earliest, next the FBC and then the RBC, that is also how they stack up on peak power also with the RBC easily winning.
I have heard other shops claim that with their porting that the RBC will make like at least 2 HP over the FBC and the stage 3. That may be true and thats fine, not knocking it. Im guessing with super top end biased flow work, its right on the money.
In my own personal test the FBC 208 made 57.7 compared to 56.2 for a HC 2. IMO the Stage 3 will fall in between them but peak wise it will be closer to the FBC 208.
IMO also the gen 1 HRC cam will suffer on the bottom end but peak out in between the Stage 3 and the FBC 208. An awesome cam for under 400 lift. I have never got along witht he HC3 but Im trying to change that on my next dyno trip.
Also thanks again for another test, its funny how it never gets old comparing these cams.
jebbin12
QUOTE(mixxer @ Feb 18 2009, 11:40 AM) *
How about the curve? Does it just peak 1.5hp higher or does it beat it most of the way up the curve?
Thanks for the info.
mixxer
QUOTE(miller450r @ Feb 18 2009, 01:12 PM) *
and thank you very much for adding in some detailed testing results.... good stuff...
mixxer
QUOTE(jebbin12 @ Feb 18 2009, 04:00 PM) *
jebbin...
both gary and i had tested with web cams in 04 when the trx450r first came out, and from our original testing...along with the fact that you can actually hear how much harsher the valvetrain is pounding.... we quickly lost interest...
you're going to have to do some research on your own on that one.... 100% of the failed valvetrains i have dealt with have had web cams in them.... not 99%.... 100%....
and it has been that same way for decades.....
once a cam's profile becomes harsh enough to be a liability to valvetrain \ engine life.... my interest goes to less than zero....
sorry...
maybe some of miller's more recent testing will be the info you are looking for
scrapper450r
i agree with mixxer and soyo on the web.
the cost to change from a hc2 or hc3 to a 208 is enough to sway me.
not to mention the possible problems it could lead to.
i have read lots of posts saying a hc3 has no personality or feel. uhhh...... who cares IMO.... it pulls and revs out just fine.
i want it to be fast, not feel fast. the 208 does come on much harder after 6500. at least from all the runs i have seen. thats why it feels faster. mind you.......... i have never rode one that has a 208 in it. just what i have read.
anyone who can feel 1 hp is a better man than me.
if the hc3 loses any bottom to a hc2, i cant tell it. mine pulls just as hard with a hc3 as a hc2, and climbs to the limiter with a dyna box. revs out much better. the hc2 leveled off before the limiter.
just my experience. i'll have some dyno runs to add in exactly 2 weeks from today.
mm450r
mixxer do you have any idea what the dyno comparison of a stage 1 to an 06 stock cam would be? just out of curiosity
556KingR
QUOTE(scrapper450r @ Feb 19 2009, 04:26 PM) *
Well put Steve.
When Dan had sent me that 550 setup, he had a 208 in it. I went out and did some riding and the engine wasnt impressing me.
When I removed the 208 and put in the little johnson it felt a little better for sure. So I left the johnson in there. Now that same 208 tore up another setup and so did 2 729's. After I personally saw that, I stopped using Web all together. I knew I could make power with other setups and I did.
Belive it or not, the Mysto was the most reliable of the big 3 offered. They say its HUGE and what not, but it was actually the least harsh on the valve train.
mixxer
QUOTE(mm450r @ Feb 19 2009, 08:32 PM) *
the stock cam in any of the trx's is a power killer..... like stuffing a sock in your exhaust.... the stage 1 is one of the most powerful torque cams available.... the stock cams are the lowest power output possible...
mixxer
QUOTE(556KingR @ Feb 20 2009, 06:41 AM) *
Well put Steve.
well put... :)
phatman1979
so is the stage 3 cam more for the big bores or does it work well with a modified stockbore 14 to 1? ever since i owned my quad i have been running the stage 2 hotcam and have always loved it. now i have gotten use to it and want some more power. how does the stage 2 cam feel after you have the head ported and flowed? is it a night and day difference? cause thats my next big step. i couldn't imagine going from 40 to 41 hp all the way to the upper 50's in hp. man it would be tough to hang on. but after awhile i would get bored and want more. lol this stuff is very addicting.
thanks guys
scrapper450r
i would recommend leaving the hc2 in there. use your money to get the port work.
if your using a stock box and rev limit, the hc2 is best.
i had one before going to dyna box. pulled strong to rev limit. making mid 50's.
with the raised rev limit, the hc2 leveled off before the new limit. the hc3 goes strong to the raised limit.
IMO........ the reason a hc3 is recommended for a big bores is because the hp and torque you give up down low can be made up by the extra displacement.
a hc3 in a stock bore with stock rev limit could possibly cost you a small amount of power on top. and some noticeable torque down low.
add valve springs and a dyna or vortex box to the stock bore, then you would see the gains of the hc3.
thats just what i think. lol
mixxer
^^^^perfect advice^^^ thanks for the input
DOZER520
very interesting info. thanks everyone!
maddmatt02
is that a crf450 frame with a trx450 swinger?
mixxer
QUOTE(Jason Hall @ Feb 24 2009, 01:26 PM) *
I swaped out the stock cam from my 02 CRF450 3 wheeler with a stage 3 HC. I was kinda amazed at how much the 02 CRF and stage 3 felt the same In my stock bore/stroke engine. My 3 wheeler has a stock compression wiseco piston with the Intake port angle slightly modded to fit the 3 wheeler frame, stock TRX exhaust with baffle removed. I was really expecting to notice a big loss of low end with the stage 3, but It was like the same cam as the 02 crf down low. I did however notice a slight Increase In top end on my Butt Dyno!!! I then put the 02 CRF cam In my 06 450ER It has the baffle removed from the stock exhaust, bumped main jet, and airbox lid removed. The TRX ran DEAD even with the trike In the sand at Gordons Well. The rider on the trx was heavier than me by at least 50 lbs, and the quad Is heavier also. So I would have to agree that the stage 3 must like the big bore engine's with bored carbs & high flow exhaust. I'm hopeing the 04/05 HRC cam will give me the top end Increase I want.
jason,
the 02 crf cams had the most radical cams of any that honda put in the 450's.... thier specs, loss of low end, and increase of top end is why honda has went through several generations of cam profiles since then...in an effort to widen the power and torque curves....
also... your current state of mods...combined with a stock TRX exhaust.... will seriously limit any cams power changing potential....
trx500r
how does the 02 crf stack up to the stg 1,2,3 cams? I have been thinking for switching to the stg3 from the 02crf, I have a 501. your piston and exhaust, ported head with ti intakes and +1 ex valves
mixxer
02CRF tests between the S1 and S2 cams.... the specs seem more radical... but that's where it tests at for me
i bought one...tested it against the S2 2 years or so ago... and then gave it away
trx500r
Good to know thanks, i will now order a stg3
Pgreenlaw
If anyone is interested, I have a stage 2 that I am wanting to trade for a stage 3...
http://www.trx450r.org/forum/index.php?sho...mp;#entry650462
mixxer
if i didn't need a S3 for occasional testing.... i'd trade you right now... :)
StephWI
Really? I've heard that every week for about a year now question.gif harhar.gif
mixxer
QUOTE(StephWI @ Mar 7 2009, 04:29 PM) *
hey ..... any chance i could "borrow" back that CRF cam steph's been running?? i like to keep a supply of test units....
steph.... sell your gray pipe to nick's bro.... you need a black one....
StephWI
QUOTE(mixxer @ Mar 8 2009, 05:03 AM) *
of course
mixxer
QUOTE(StephWI @ Mar 8 2009, 09:23 AM) *
of course
