450 SLUG
Feb 3 2009, 04:36 PM
i just had my crank balanced w a venom 12.25 stock bore piston and im wondering if i can upgrade to a 480 pump gas piston without rebalancing? i weighed the stockbore if iu remember right it was 266 grams? sound right ??
mixxer
Feb 6 2009, 10:27 AM
i'll post the weight a bit later
450 SLUG
Feb 8 2009, 09:02 PM
not trying to rush you but i nee dthis info to order my new piston to get my build together
mixxer
Feb 8 2009, 09:19 PM
i forgot all about it with all the LTR dyno work i was doing....
so sorry...
stock bore 12.25:1 = 286 grams
480cc\97mm 12.25:1 = 297 grams
i will tell you this though..... switching from the stock brick in the 04-05 TRX's... to a much lighter aftermarket piston... there is no noticeable added vibration whatsoever...and there is usually at least an unbelievably HUGE 80gram difference there....
stroker cranks require re-balancing because of the huge amount of steel they take off the cranks for piston clearance @ BDC.....
the stock cranks are pretty much vibration free with a wide range of pistons sizes and compressions....
450 SLUG
Feb 9 2009, 03:53 PM
cool thanks for the reply, just to be safe im gonna see what crankworks thinks but ill def be calling for a piston in the next day or 2
just talked to crankworks and they said 10 grams is ok- 15-20 might be too much tho
450 SLUG
Feb 9 2009, 04:00 PM
oh yeah where should i send the cylinder to get bored???
mixxer
Feb 9 2009, 06:15 PM
milennium
max power
U.S. chrome
any of those places will do a great job
450 SLUG
Feb 12 2009, 07:14 PM
sent you a pm, i weighed both pistons and got different #'s
266g 450
295g 480
im pretty frustrated and out of $$ i may just bore the cylinder and run the + 30g piston and hope for the best
mixxer
Feb 13 2009, 12:28 PM
QUOTE(mixxer @ Feb 8 2009, 09:19 PM)
so sorry...
if you don't have a stroker , you will be fine...
the rpoble comes from the crank...not the piston weight
