dagger350
Jan 28 2009, 09:20 PM
Here is my 05 450R. I have been working on it during 2008, 2009 and plan to race in 2010.
Here are the current modifications:
Venom exhaust
Carb jetting: pilot jet size upped to 50, HRC needle jet on 4th clip, main jet 175
13T drive sprocket
Front FOX podium Triple-rate
Holz LT +2.5 A-Arms
Rear FOX podium X DSC
Holz XC rear linkage
Kenda Klaw on Douglas beadlock
Maxxis Cross on ITP
G-Force axle
Lonestar billet rear hubs
Pro-Armor Billet Shifter
Pro-Armor Fat Nerf bars
Pro-Armor Pro XC bumper
Pro-Armor Pro-race grab bar
Pro-Armor Tethered Kill
Power MADD Hand guards
Maier hood
Mod Quad parking block
NAC case saver
Thanks to Org members fhrtrx450r33, FourWerx, MAD B, D Bergstrom, Paul Woodward and Venom Performance for various parts and installation tips.
Current Pic:
< 2010 pic coming soon >
dagger350
Jan 28 2009, 09:25 PM
All Stock picture from a couple of years ago.
07450rcrunkmode
Jan 28 2009, 09:26 PM
do you have an axle already?
dagger350
Jan 28 2009, 09:31 PM
QUOTE(07450rcrunkmode @ Jan 28 2009, 08:26 PM)
I have some parts waiting to be put on when it gets warmer. They include an axle, +2 swingarm, carrier and hand guards.
07450rcrunkmode
Jan 28 2009, 09:47 PM
i love the way your R sits that low.. how did you get it that low? with just holz xc linkage?
hondaman01
Jan 28 2009, 10:25 PM
very nice, the only other person i have ever seen with the same front shocks
how do you like yours?
TRX450RACER174
Jan 28 2009, 10:46 PM
Yeah i was wondering the same thing how do you guys like the conventional Fox shocks?
dagger350
Jan 28 2009, 11:26 PM
I like the FOX podium both on front and back. They smooth out the ride and kept the landings on jumps manageable. BUT I have no reference other then stock shocks. I worked with Matt and gang at HOLZ racing to setup the suspension with a lot sag to it. I will let you know more when the season starts, this fall I got only a few rides on it before before season ended.
dagger350
Jan 28 2009, 11:30 PM
Here's a pic when I was switching out the front end suspension this fall.
dagger350
Feb 16 2009, 07:22 PM
Ok, I have read the swing arm bolt stories and I myself have tried all weekend to remove bolt. No luck just an aching back. What really works? Should I go out and rent/buy a air impact hammer to remove this bolt?
The Haunted 450R
Feb 16 2009, 07:46 PM
Nice front end, and you don't need an impact gun for the swingarm bolt. You just need to tap it out with a hammer while someone wiggles it back and forth with the socket on the other side. Also, moving the swinger up and down to relieve tension works good.
Vigs07R #9
Feb 16 2009, 07:50 PM
nice build. so you are running xc tires for mx?
comales
Feb 16 2009, 07:51 PM
Very nice on the project man. Props
hondaman01
Feb 16 2009, 08:01 PM
QUOTE(The Haunted 450R @ Feb 16 2009, 07:46 PM)
wrong, sometimes that bolt gets EFFIN FROZEN to those sleeves in there that are actually the inner race to the bearings
there really is no way to get these infrozen some ppl have to cut them out and that messes things up
mine was frozen the first time i took my swinger off and it took everything to get it out i ended up screwing the nut on the end of the bolt and beating the piss outta it with a 10lb sledge hammer, FINALLY broke it loose after about 30 minutes of hitting it
you can try putting vise-grips on those sleeves, you can barely see them/get to them but they run between the swinger and the engine on the bolt and then hitting the bolt with a impact to try and unfreeze the sleeves but i will tell you this did not work for me at all
and i do suggest when you put it back in cover that thing in never-seize to keep it from happening again there is a mod you can do to make your pivot bolt greasable or you can buy a stainless steel bolt that eliminates the problem as well
either way good luck, your probably going to need it
dagger350
Feb 16 2009, 08:55 PM
Thanks for the support, I will try again this week after I get some additional help to break loose the nut. Does anyone know the exact size of nut, maybe 19mm? Bolt is 17mm.
hondaman01
Feb 16 2009, 09:01 PM
i think the nut side is about 21mm or so and the bolt side is 17mm i believe but im probably a little wrong
dagger350
Feb 16 2009, 09:04 PM
I installed XC because these rear tires are from my 350X. Since I ride for fun in the trails and the family farm, these had the 6ply needed to handle the thorns, etc in the woods. I plan to try to race MX this year and going to stay with these tires.
The Haunted 450R
Feb 16 2009, 09:10 PM
Ya I remember putting the nut on backwards and pounding it out with a regular hammer. Mine is an '05 so it was pretty stuck on but I managed to hammer it out.
dagger350
Feb 17 2009, 10:58 AM
Swingarm bolt is out! Liquid Wrench is an awesome product. Got bolt out in 30 minutes with a few hits of the spray.
450Rider707
Feb 17 2009, 12:07 PM
My bolt WOULD NOT come out no matter what... we had three people working at once on it, one spinning it with an impact, one putting heat on it with a torch, and the third hitting it with a hammer, it WOULD NOT come out. Mine was frozen to the sleeves and also bent to boot, you could watch the back of the motor move up and down as the bolt spun.
Mine had to be cut out with a torch.
I put in another stocker that had been molycoated, and that solved all my issues, went an entire race season without touching it again and pressure washing it, end of the season it slid out with two fingers...
$15 to have it coated...
IMSROLL450R
Feb 17 2009, 12:34 PM
Hey dagger where are you at in Illinois? We should meet up at a track sometime.
dagger350
Feb 17 2009, 12:52 PM
West Springfield area, I ride the track at SFDR in Talyorville. Haven't raced there yet, hope to this year.
IMSROLL450R
Feb 17 2009, 01:38 PM
QUOTE(dagger350 @ Feb 17 2009, 11:52 AM)
Dude I live just on the east side of Springfield, we ride Taylorville ALOT. PM me next time you are going and I will meet up!
dagger350
Feb 17 2009, 02:07 PM
Sure, but it wont be until I get bike back together and it warms up. I really dont like cold weather.
IMSROLL450R
Feb 17 2009, 02:09 PM
QUOTE(dagger350 @ Feb 17 2009, 01:07 PM)
Dude me either. Sometime in March we will be back out there a lot more.
dagger350
Feb 25 2009, 02:05 PM
moving rear reservoir placement to further under seat.
Got2RideRed
Feb 25 2009, 08:20 PM
omit
dagger350
May 6 2009, 06:39 PM
Current pic updated:
dagger350
May 6 2009, 06:42 PM
Venom Exhaust pic- Huge performance improvement. Thanks to Teresa at Venom Performance.
DIRTWIZARD
May 6 2009, 08:32 PM
Very nice!!!!!Can you still get those fox shox with the springs for the front and if so where?????
dagger350
May 7 2009, 09:06 AM
I got mine from Matt at HOLZ racing last fall. Not sure if they have anymore you can check them out here
http://www.holzracingproducts.com/
dagger350
Jul 30 2009, 03:27 PM
I have not made it to a race this year. I dumped the bike on practice track the week before first race. Recently, I have been able to get back on the track. Hopefully more to come soon.
dagger350
Dec 9 2009, 12:15 PM
I did finally get to a race on Oct 4 in Taylorville. Placed third and, to be honest, only three showed up. I really got tired in the last moto. I need to be in better shape next year.
S&H_Racing
Dec 10 2009, 11:36 PM
ha that sounds like what i used to be. i remember one time only 2 quads showed up for a race so they let us race for free and we did more laps than the dirtbikes
dagger350
Dec 24 2009, 06:09 PM
Current pic updated on first page with XC tires.
Here is pic with Duro tires.
