sebas
Jan 10 2009, 01:11 PM
Hi, If someone know if its easy to change the driving bearing( Where the stem is seated)
at home.
Because I am needed to change mine.
thanks for any answer.
jebbin12
Jan 10 2009, 10:20 PM
QUOTE(sebas @ Jan 10 2009, 12:11 PM)
at home.
It is pretty easy. Put your bearing in the freezer for a couple hours and then heat up where the bearing goes on the frame and it should slide right in with minimal help of a dead blow hammer if needed.
Scro
Jan 15 2009, 03:41 PM
When you remove the seal out of the frame, there is a snap ring holding the bearing in. Be sure you remove this before you go beating on the old bearing to get it out.
sebas
Jan 18 2009, 11:55 AM
ok thanks.
And wath could I remove from the quad to work fine, Stem? A-arm? Front Plastic?
Wath tool I need, I have alot, but I dont really know how to remove the bearing.
So if i understand, I remove the Seal, the Snap Ring, And the bearing.
