right now the needles are on the third clip from the top with a 160 and 165 main jet. it has a 12:1 je piston, stg.2 hotcam, and a full hmf exhaust that i have cut to 8 inches. my problem is at higher rpm's it starts sputtering and running bad but the lower rpm's pull hard. when i drop the clip to the 4th from the top the lower rpm's start sputtering and the higher rpm's clear up and really pull hard.
should i leave the needle on the third clip and try to increase the main jets to around a 165-170 or maybe even 170-175?
thanks in advance for the help.
seth
