Full Version: Need help
ryde450
Whats up guys, well I had my 05 trx450 stored for about 5 months, I tryed to start it with the choke on and started up after a few tries, But when i turn the choke off it will not hold the idle, it only starts with the choke on and will not idle with it off. I started it with the fuel that was in there for 5 months, do u guys think it clogged something up in the carb?
StonedInNy
QUOTE(ryde450 @ Oct 21 2008, 02:21 AM) *
yea you need to drain all that old gas and clean your carb out then try to start it
ryde450
whats up, well i cleaned the carb out and that did the trick, one thing though i lost the dynojet washer that goes above the e-clip, would that make it bog down at full throttle because thats the only issue i have now, thanks for your help!
