Full Version: Piston and Cam upgrade
sandshots
one of our friends has a susuki 400 i think its an 06 and wants to ugrade to a higher performance cam and piston.
type of riding is general duning and trails.it has to stay on pump gas.
what piston what brand and wich cam woud you guys recomend?
Vader
He might be set on these mods, but I would approach modding a pump-gas LTZ differently. The carbed models have a horrible CV carb, that needs replacing immediately. They need an FCR on there. I put a $100 YZ250F 37mm FCR on my old Z400 (YFZ 39mm's work great too), trashed the airbox completely, and bolted up a home-made "ESR-type" filter with outerwear. Regear it, dynotune it, throw on a set of 6-paddle haulers or Brats... you'd be surprised how well this set up runs.
You can also remove the middle-layer of the stock head gasket, leave stock piston in there, and add a cheap hotcam intake cam (stock exhaust cam), and get even more cheap pump-gas performance.
woodwardspecialties
we have wiseco and JE pistons in stock for the Z.... also have a set of hotcams at a killer price.... have you friend PM me... or you can... and i can work up some prices for you.
Congrats on the newborn!
sandshots
QUOTE(woodwardspecialties @ Sep 12 2008, 02:49 PM) *
thanks, really appreciate it.
i didnt know the z came with two cams, is it better to replace both of them?
vcforlife15
yeah its not unicam I would do both! there was an older style of hotcams for it that were better than the current ones(do not rember why). check out z400central and mabey you can pick up a used set cheap, if your friend is cool with that. Also I would recomed the carb thing like mentioned above! There was also a drz base gasket that bumped up the compression a little.
woodwardspecialties
QUOTE(sandshots @ Sep 12 2008, 09:24 PM) *
yep... 2 cams.
the hotams set is meant to work together... and has an auto decomp setup.... the old style hotcams (that were discontinued 2-3 years ago) did not have the auto decomp
Kfxguy
New style hot cams are poo.
woodwardspecialties
QUOTE(Kfxguy @ Sep 25 2009, 12:13 PM) *
thats interesting.... care to back up your comment with some information?
elf
QUOTE(woodwardspecialties @ Sep 25 2009, 07:54 PM) *
They are not as aggressive as the old style cam. They work a little better than stock. You notice a difference with them put in but its not huge.
Hotcam- Newstyle Stage 1- ...........9.1 @ 238*both Int and Exh
Hotcam- Oldstyle ............................9.6 @243* both Int and Exh
Stock Z400/DRZ400S & SM cams-.............IN: 8.48 @ 227* and EX: 8.2 @ 243*
sandshots
x2
