wishiwerfishinn
Aug 11 2008, 05:03 PM
has anyone installed grease fittings to their balljoints?
if so where did you put them at, any pics?
**07white**
Aug 17 2008, 11:07 PM
if they didn't come with grease fittings, then I wouldn't bother trying to put them in. the balljoints that JD uses are meant to be permanently sealed. They don't let anything in or out, thus they should never need lube. They will eventually wear out and need to be replaced, but they require no maintenance.
wishiwerfishinn
Aug 17 2008, 11:25 PM
truee, its not a big concern.
just curious to see if anyone has done it.
its more for the sake of cheap preventative maintenance to help em last a lil longer.
astro boy
Aug 25 2008, 04:35 PM
Mine only lasted 5 months, and he will not ship to canada anymore.
**07white**
Aug 25 2008, 11:36 PM
I've had mine for about 6 months and not a single issue. I started to get a squeek from the bushings, but a little clean and lube fixed that.
