Full Version: CHEVRON DELO 400 15W40 *UPDATE*
dez
Just to let all of you guys know about Delo 400 15W40 ... It has come to my "desk" that the new formulation ... Meaning if it says CI-4 Plus
On the back of the bottle it has Moly now ... In the neighborhood of 100-200 ppm ... So, don't use this new formula in the trans ...
It looks as if now maybe the only 2 oils that are Dual purpose Diesel/Gas that don't have moly is Rotella ... I'll check it out ...
It's too bad too, I have 4 jugs of delo now that I can't run in my 450R trans abd Rancher case ... Oh well ... I'm stocked for the R's motor side for a long time now ... haha
dez
KillerQuad
QUOTE(dez @ Feb 22 2005, 12:28 PM)
dez
YEP.... thats why i just switched to the Dumonde Tech LWHS Racing Tranny Oil.....
That does suck i have about 3 cases of 1 gallons.... but hey... i also have about 6 Diesel engines that run around here as well.....
jjohnst03
The rotella T oil has worked fine for me. I like it.
midwestrider
dez has that you talking about the miltec? Where can i get some ?
safety
I found this from another forum posted on 03-07-2005 at 09:25 AM.
We have confirmed that Chevron has recently made a change to the formulation of DELO 400 Oil to meet the new CI-4+ specification. To meet the new specification, Chevron has added 260ppm of Moly. Moly is not compatible with wet clutches.
The new formulation appears to just be making its way into distribution, our local Chevron Oil dealer still has some CI-4 oil on the shelf. DELO 400 with the CH-4 specification is also ok.
Although designed for large diesel engines, DELO 400 Oil has been a popular oil for use in motorcyle engines because of it's anti-wear properties and very good wet clutch performance. Rekluse Motor Sports has recommended DELO 400 for use with the z-Start clutch.
After speaking with Chevron Technical support, it does not appear that Chevron has a suitable replacement product.
Update: I spoke with Shell technical support, the Rotella T products that meet the CI-4+ specification do not contain any friction modifiers and should be a good choice for wet clutch use.
Thanks,
Al Youngwerth
President, Rekluse Motor Sports
sandshots
the 450r manual calls for honda's GN4 10w-40...
so this means i can use this oil for both sides of the crank case?
BGATV450Racer
QUOTE(KillerQuad @ Feb 22 2005, 12:41 PM) [snapback]63146[/snapback]
thumbsup.gif Thanks for Supporting my Sponsor! Dumonde Tech all the way.
I buy it by the Gallons! They also sell Spider Grips.
Very good Oil!
QWK 450
have you looked at SCHAEFFER 15-40 diesel eng. oil? not too sure if it would work but i'll try to look at the bottle tomorrow.
