Full Version: 01 yamaha bear tracker Question
redkaz04
Ok, our family has a beartracker that blows a 15 watt fuse everytime I hook up the battery.(suppose to be a 15 watt fuse there, I have tried all the way up to a 30) Or if I put the fuse in, then connect the battery it then blows the fuse imediately. The fuses that I speak of are located right beside the battery with a wire coming in and a wire coming out, one 15 watt fuse on either side. So, how on earth do I solve this one?
MDFMac
QUOTE(redkaz04 @ May 26 2008, 06:05 AM) *
it is blowing the fuse becouse there is a short to ground or what ever that fuse powers is bad. start unhooking things till it stops blowing fuses, then you know what your problem is. putting in a 30 amp fuse will just let the wires cook a little more. will not cure the problem
