Full Version: ds 250 problems
Honda TRX450R Forums: Honda TRX 450R Forum > Other Quads > All other quads
trx_bryn
k well.. this thing died one day, so we cleaned the carb, etc. and now it fires occasanaly but wont run.. any ideas??
need help quick...
Cleatus
So are you saying it doesn't fire consistently, like you are watching the spark plug and it doesn't fire all the time?
if thats the case something is wrong with the stator/magneto?
just a suggestion.
trx_bryn
no its not that, its got great spark,
Cleatus
QUOTE(trx_bryn @ Feb 16 2008, 11:48 AM) *
How long has it been sitting? Did you put fresh gas in it? Check the fuel line for blockage? You said it just died one day, did it restart after it died?
Actually could be a number of things.
trx_bryn
no it hasint ran since.. its weird, its got spark, all the fuel lines and carb is clean, we havent put freash gas in it however..
Cleatus
could it have jumped timing? How is the compression?
want2bfast
fresh gas is always a +.
trx_bryn
well, weel go try compression testing er... timing seems like a far cry but its possible i guess..
trx_bryn
what should the compression be on that thing??
Cleatus
QUOTE(trx_bryn @ Feb 16 2008, 12:01 PM) *
Yes it does, but you stated it died and never ran since. Something caused it to die?
If you do a compression test first that will tell you if the valves possibly got bent. I would still look at the timing, to eliminate it. You say it's weird, well this has happened to me and it did bend my valves. So it is possible.
trx_bryn
ok well were gonna go look at this thing again./
Cleatus
QUOTE(trx_bryn @ Feb 16 2008, 12:05 PM) *
I would just pull the plug and turn it over and see if you can hold your finger over the spark plug hole.
trx_bryn
mmkoy..
trx_bryn
k well now it idels and wont rev all the time.. what we did to make it run was put new gas in it..
Cleatus
QUOTE(trx_bryn @ Feb 17 2008, 02:21 AM) *
lol, isn't it usually the simple stuff? Does it seem to run better when the engine is cold? The reason I ask, is the choke could be stuck.
