Full Version: Trail Tech -4oz Fly Wheel (installation)
BOONE450R
Well i got my -4oz Fly Wheel back form Trail Tech and i thought i would share the installation and review of it with you guys and girls.
BOONE450R
This installation is very easy to do and It will require the following tools.
8mm socket 1/4 or 3/8 drive
Ratchet wrench 1/4 or 3/8 drive
Small extension 1/4 or 3/8 drive
12mm socket 3/8 or 1/2 drive
17mm socket 3/8 or 1/2 drive
19mm Deep socket 3/8 or 1/2 drive
Impact wrench 3/8 or 1/2 drive
Torque Wench 3/8 or 1/2 drive
Adjustable wrench
BOONE450R
You start buy draining your oil, then take off the shifter, and the bolts that hold the outside cover on.
BOONE450R
Once the cover is off you well then have the Fly Wheel in site. You do not have to take the oil filter out if you dont want to just the outside bolt on the the cover. Start buy removing the Fly Wheel nut with the impact gun, once the nut is off install the Fly Wheel puller make sure you screw the fly wheel puller all the way down. If the center bolt is not backed out all the way the puller might not screw all the way down.
Once the puller is installed run the center bolt in till it bottoms out on the crank shaft. Now you can use the impact gun to tighten the bolt on the puller which will in turn pull the Fly Wheel off. You might have to use and adjustable wrench to hold the puller if it starts to turn (if you have your spark plug out).
BOONE450R
Once the Stock Fly Wheel is off you can see the differences between the two.
BOONE450R
Make sure you clean the New Fly Wheel off before installing it. Mine had small pieces of metal stuck to the magnet. Now install the -4oz Fly Wheel and tighten the nut with a Torque wrench(47lbs) You can tight this nut buy having someone sit on the quad and hold the breaks down while its in gear to keep the motor from turning(you will have to temporally place the shifter back on to get it in gear if its not).
After that check the gasket out to see if its torn or need to be replaced. Use a new gasket if necessary. Then reinstall the outside cover and torque the bolts(7.2lbs).
Double check your work to make sure everything is right and looks good, then filler up with some fresh new oil(change the filter if you like) and let her rip!
This whole process took about 30min with me taken pics(having to clean my hands before i touched the camera)
BOONE450R
I will be giving a review on the product as soon as i can get some more ride time on it.
lukester720
Thanks Boone, thats an awesome how-to! Do you care if I add this in on the flywheel FAQ?
BOONE450R
Thanks Luke B) No i dont care.
#8trx450r
Geeese Boone, do you ever ride that thing? Its spotless <_< !
J/P bud, 8
BC_Duner
yep nice how to,
just fyi for thos eeven less patient than i...
i did this in a parking lot, and instead of draining oil you can just tip the quad on its side (or damn close)
if its windy and dusty don't try this outside.
