the bummer is that it is pretty much impossible to intake tune without an A\FR meter equipped Dyno....
the good news is that i do have a dyno... :) ....and i'm all for sharing info with you guys....
the topic has been touched on before, but there is a BUTTLOAD more behind intake tract tuning than what CFM an intake flows..... velocity and relative straightness are very inportant.... but length and volume are BIG factors that need to be fine tuned once the mass cfm requirements are met....
the intake tract\ tuning is dominated by harmonic pressure phenomena..... reflected pressure waves within the system..... primarily caused by the opening and closing of the intake valves.... and as waves are known to do, they travel back and forth within confined spaces and reverse their pressure sign when they meet change in the volume they travel in.....
at some rpm you can have the wave travel many times through a carb within each engine cycle...and that would effectively over carburate with a rich mixture, since the carb doesn't care which way the signal is traveling, or if it has already been through the carb body once or twice..... every pass of a negative pressure will get more fuel added to it.....
and some rpms will see the intake valves opening while a wave is traveling towards the air filter...and creating a negative pressure (vacuum) in the intake tract @ the exact opening of the intake valves..... which means there will be a delay in the influx of the intake charge since the downward traveling piston will have to move far enough create a vacuum greater than the vacuum present in the intake tract before any cylinder filling will begin......
the best tuning situation of all occurs when the prerssure wave is holding a slightly positive pressure of correctly mixed fuel\air just behind the valves at the moment of valve opening...... a small "boost" pressure if you will... pushing in fresh mix before the piston is creating any of its own vacuum....
even more magical would be, if , at that moment of cam overlap (exhaust valves not quite closed\ intake valves just opening), the exhaust system was delivering a vacuum..... so a pull from the tail of the exhaust event mated with a push from the intake tract....pure magic in terms of engine effectiveness!! and BTW.... exhaust pressure pulses, both positive and negative, find their way into the intake tract...and add another level of complexity to all the pressure wave phenomena....
all sorts of factors influence the intake tuning..... since the engine isn't a bunch of separate components, but rather the sum of all its parts.... :
air box...filter...intake..carb size...cam selection... porting...compression...bore size...exhaust system..etc..
all of those can, and do, affect the tuning of the intake tract ..... easier to build your engine component package completely...and then tune in the intake at the end......
and..one intake may be just perfect on one engine setup...and terrible on another... gotta test to find out...
anyways... my current YFZ setup has shown a VERY dramatic improvement in A\FR & power graphing.... i have seen bigger changes in power... but NOT in A\FR
and these are the SAME intake....with the only difference being overall length being shortened by 1.25"...and it has worked the same with cam & displacement changes since it was modified...! nice...
first graph is from the first tuning set of modded yfz with the stock cams... the only difference is the length of the intake tube....
while the jetting would still be in the normal\ fine fluctuation range on the un-cut version... pretty normal for carbs, and if i can keep A\FR fluctuation within 1~1.5 points i'm usually satisfied....
but what IS going on other than a\fr jetting, is negative pressure wave timing hurting cylinder filling effectiveness....once the intake was shortened, everything became better timed & jetted....
blue is with full length intake
red is intake cut by 1.25"
Click to view attachment
and the rest of the jetting\ graphing has been perfectly consistent during the rest of the testing
