a little background of what ignition advance even means... some history too....
ignition advance refers to the amount of crank degrees the spark is triggered BEFORE the piston reaches the top (TDC) of the compression stroke...pretty simple...
but why would we want to light the mixture BEFORE TDC..?? wouldn't that push the piston back down?
the reason is that the entire charge doesn't completely combust the moment the spark occurs....there is a slight lag time between the initial spark kernel and full on combustion pressures happening in the cylinder....
if you lit the spark at Top Dead Center.... the inertial rotation of the crank will already be pulling the piston downward before significant combustion takes place....the combustion charge would, in effect, be chasing the piston for a bit, rather than pushing it....which would be a waste of good combustion pressure.....
on the other hand...IF the charge was lit too early before TDC.... you will get NEGATIVE work form your combustion charge in that it will waste inertial crank energy while the crank\piston is still trying to compress the combustion charge..... assuming it doesn't overcome it entirely and push the piston back down the bore without it ever reaching TDC .... some of you have had some shin smacking or knee wrnching experiences during kick starting when that very event happens... i personally have a divot in my right shin from my days of starting high compression 250R's sans boots..... if any of you haven't had the pleasure...and would like to experience it without buying a high compression 250R... just grab a ball peen hammer and swing it , ball end, as fast as possible towards your right shin... you know you've done it right when your eyes water...or you fell as though you want to throw up for no good reason...lol...ah memories....
back to spark advance... many things will influence the burn rate of the combustion charge...:
fuel....combustion chamber shape...temperature..humidity...engine speed..squish velocity...cylinder filling \ throttle opening.....and more..
another thing that should be considered is engine load... or how much resistance the piston is seeing against it's desired travel....high resistance like being in high gear with an open throttle can do some nasty things to the burn rate VS space available...spark knock and detonation....
at low rpm and open throttle conditions you will have significant load on your engine..... combine that with the slower movent of the piston...and you don't want or need a whole lot of spark advance @ low RPM...it would be easy for the combustion process to get too big of a head start in pressure rise against the still upward traveling piston.....
as you engine speed increases, so does the need to ignite the mixture sooner to give it adequate combustion lead time to "push" rather than "chase" the piston down the bore after it reaches TDC....
as engine speed goes up... so does the cylinder filling and charge turbulance...both of which increase flame front speed...and at some point in the RPM band you don't need to add in any more spark advance because the flame speed increasing cylinder filling and turbulance automatically keep pace with speeding up flame travel in step with increasing RPM....
so you can see that there is a lot of optimization that can be done to match the timing of lighting the mixture to match it for most benefit in a pericular engine setup and running condition....
in the "Bad Old Days" of point triggered ignitions (mechanical switches opened and closed by a cam lobe to signal spark events).... you had "base timing" the amount of advance you adjusted the assembly to start at by its positioning... and then there was a centrifically operated spring and weight assembly that adjusted the advance per rpm by mecahnically moving the points in relation to the cam lobe that opened them.....
that is a 2D ignition advance system ... as rpm increased, the weights moved the plate and ignition advance increased...nothing else mattered to the ignition except what rpm the engine was running at..not throttle position or gear selection...nothing but rpm
later on came the mechanical 3D equivalent ignition system....where a vacuum line was plumbed from the intake manifold to a diaphragm assembly that moved the whole point assembly based on the amount of vacuum in order to take some sort of engine load\ throttle position into account.....
lets jump out of that era into more current electronic ignitions...as they apply to our off road dirt bikes and atv's..... where an electronic \ magnetic pickup reads the crank position by a tab on the flywheel...and sends that information to the CDI\ ignition box..... coming into production in the 70's..and were the rule of the day by the 80's...
these were still a 2D style of ignition...the CDI could tell what RPM it was running at.... and pre-set ignition map told it at what point to fire based purely on engine speed.....
during that time, many aftermarket ignitions were made with different available "Maps" to choose from...and it made for better performance and sharper throttle response in lots of instances...but the key then..is the same is it has always been...to match the advance curve to the needs of the particular engine build at hand...and still nothing took into account anything more than engine RPM...so ignitions were mapped for basically best full throttle operation.... and that is a compromise because ignition advance requirements change with percentage of cylinder filling...a lesser filled cylinder will have a power advantage with more spark advance due to the slower burning rate of the lesser fill...
most current performance off road machines have a TPS (throttle position sensor) as part of the carburetor or thropttle body... and the TPS sensor feeds throttle percentage opening to the CDI\ ignition system.....
so we are currently using electronic 3D ignition advance mapping..... which is great.... and it came about as a way to adjust our engine's apark advance curve to take into account agreater amount of variables to optimise our ignition timing for best power and throttle response over a wider range of running conditions.....
the ignition now knows what rpm it is running at...and also how much throttle opening\ cylinder filling is happening via the TPS.....
within the programming is a Map for the entire rpm band @ closed throttle
and a map for the entire rpm band at wide open throttle (WOT)
the percentage of throttle opening is fed to the ignition via the TPS..... and the ignition constantly\instantly interpolates and adjusts the timing advance as a percentage between the fully open and closed throttle advance curves in an effort to maximize power over the widest range of operatiing conditions.....
in all engines (exception being the 5-valve Yamaha's).... the Wide Open Throttle setting requires the least spark advance for best power.... and least advance is also the least dangerous to run with as far as engine pressures are concerned....SO.. in absence of of TPS input, the ignitions are programmed to default to the WOT curve only...giving less than optimal power\ throttle response when not at WOT....and the SAME power as always when @ WOT conditions (like dyno runs & drag racing)....
you have to watch out for the cheap aftermarket ignitions.... as in not Dynatek or Vortex....and most being made by procom with each speed shop slapping their own sticker on the box and selling it as their own....because these cheaper ignitions only have a single 2D curve mapped in them, and don't use any input from your TPS...also they tend to have a big amount of advance...which will make a stock engine feel snappier...but can be detrimental... and even dangerous to run in a fully built engine
i decided to bring this topic up because Kam @ KBR sent me a Dynatek ignition to see what the upper reaches of my new YFZ's power curve looks like..... and then i had to look @ the available YFZ curves on my Dyna programming software.....and had to notice that the YFZ curves were the 100% opposite of all 4-strokes other than this 5-valver...!!
the YFZ runs LESS advance at partial throttle openings (yes, even the stock curve from Yamaha).... and MORE advance at full throttle openings...... the inverse of the rest of the universe...lol...
i'm going to be thinking about that for a while....
and maybe that is why plenty of the YFZ owners have reported better throttle response with the TPS deactivated..??...it runs a maximum advance full time when deactivated.... still seems sort of counter intuitive... but that's because my intuition has been based on 2 & 4 valve combustion chamber curves
anyways...here's some TPS 3D ignition map graphs from the TRX and YFZ to check out....
Click to view attachment
