TRX450R Online Reference Material
Manuals, Links, Graphs, Diagrams, Utilities, etc....
The #1 Online Reference!!!
_________________________
SERVICE MANUALS
SERVICE MANUALS
Service Manual - Honda TRX450R - 04/05
31.5MB downloadable ZIP file. Store it on your computer to view and print from.
http://www.bluezone.net.au/wheatbix/05trx450rSM.zip
(Thanks wheatbix)
Service Manual - Honda TRX450R - 06
85MB downloadable ZIP file. Store it on your computer to view and print from.
http://files.filefront.com/06trx450rSMzip/...;/fileinfo.html
(Thanks 06erDJ450)
HRC Manual / Parts List - Honda TRX450R 2006
Photo scans of 2006 TRX450R Competition Kit Manual.
http://www.trx450r.org/forum/index.php?sho...c=31716&hl=
(Thanks nathan 89)
Maintenance Guide - Honda TRX450R 2006
Honda Maintenance Guide
http://www.trx450r.org/forum/index.php?showtopic=37188
(Thanks lumi & dirtdevil)
Maintenance Guide
Misc maintenance material from Honda for all years
http://www.trx450r.org/forum/index.php?sho...c=37189&hl=
(Thanks lumi & STEVE SJH)
HRC Kit Manual - 2006/2007
2006/2007 HRC Kit Manual in PDF format.
http://members.cox.net/riosluis/2006-2007%20HRC%20MANUAL.pdf
(Thanks rioslu)
OEM PARTS CATALOGS
OEM PARTS CATALOGS
OEM Parts Catalog - Service Honda - 04/05 TRX450R
Used for Reference - Great for printing whole catalog - PDF Format
http://servicehonda.com/hard%20parts/atv/t...2004trx450r.pdf
OEM Parts Pricing Page - Service Honda
Used for pricing and purchasing OEM parts from Service Honda
http://www.servicehonda.com/parts.php
OEM Parts Finder / Fiche - Honda of Troy
Used for Reference and Purchasing of OEM parts.
http://www.yamahaoftroy.com/fiche_select.a...#FicheSelection
(Thanks mstrav)
OEM Parts Finder / Fiche - Planet Honda
http://www.planethondaracing.com/cgi-bin/hondaparts/parts/
OEM Parts Finder / Fiche - Honda of North Texas
http://www.hpnt.net/fiche_select.asp?vcc=A...#FicheSelection
(Thanks sredish)
OEM Parts Finder / Fiche - Motosport.com
http://www.motosport.com/offroad/oem.php?&nav=7
(Thanks Rob450R)
INSTALLATION AND MODIFICATION GUIDES
Uncorking your R on a budget
Instructions for simple and cheap modifications, to get the most out of your stock TRX450R.
http://www.trx450r.org/forum/index.php?showtopic=40841
(Thanks sredish)
HRC Power Up Kit Installation
Instructions for installing 04/05 Honda Racing Corporation Kit.
http://www.rockinhorseweb.com/hrc_powerup_kit_install.htm
(Thanks Rockin Horse)
High Compression Piston Installation
Instructions for installing aftermarket high compression piston.
http://www.rockinhorseweb.com/Piston_Install_page1.htm
Engine Oil Change
Instructions for changing your engine oil and filter.
http://www.rockinhorseweb.com/motor_oil_ch...for_trx450r.htm
Transmission Oil Change
Instructions for changing your transmission oil.
http://www.rockinhorseweb.com/transmission...ge_for_trx4.htm
Factory Clutch Modification
Instructions for removing the judder spring, seat, and engagement clutch disc. Helping with clutch disc life and more positive engagement.
http://www.rockinhorseweb.com/Clutch_mod.htm
Cam Installation
Instructions for installing aftermarket cam.
http://www.rockinhorseweb.com/Cam_install.htm
Header Wrap Installation
Instructions for applying insulating header wrap to your exhaust system.
http://www.crfsonly.com/howto/header-wrap/...header-wrap.php
Grip Removal Instructions
Instructions for safely and effectively remove old grips from handlebars
http://crfsonly.com/howto/grip-removal/grip-removal.php
ESR Intake Modification Thread
Instructions for modification of ESR Airbox Eliminator for better air flow.
http://www.trx450r.org/forum/index.php?sho...c=28659&hl=
(Thanks mixxer)
06/07 Headlight and Hood on an 04/05 Installation Thread
Instructions for installing an 06/07 headlight and hood on an 04/05.
http://www.trx450r.org/forum/index.php?sho...c=30342&hl=
(Thanks mstrav & gumby46)
Swingarm Installation
Instructions for installing a Houser Swingarm, applies to most other swingarms as well.
http://www.houser-racing.com/WSWrapper.jsp...uides/I0403.htm
Steering Stem Installation
Instructions for installing a Houser Steering Stem, applies to most other stems as well.
http://www.houser-racing.com/WSWrapper.jsp...uides/I0406.htm
Valve Adjustment - HOW TO
Excellent step-by-step instructions for adjusting your TRX450R's valves.
http://webpages.shepherd.edu/ghott01/valve...adjustment.html
(Thanks ghott)
Nor*Cal's TRX450R Tail Light Mod
Excellent step-by-step instructions for relocating your rear tail light up to just below the rear fender. Creates a very clean look and also puts your rear light in a less vulnerable place.
http://www.trx450r.org/forum/index.php?act...st&id=20320
(Thanks Nor*Cal)
Caster Adjustment
Instructions for Caster Adjustment.
http://i42.photobucket.com/albums/e318/gum...rAdjustment.jpg
Camber Adjustment
Instructions for Camber Adjustment.
Toe-In Adjustment
Instructions for Toe-In Adjustment.
http://i42.photobucket.com/albums/e318/gum...nAdjustment.jpg
Ball Joint Removal
Instructions for Ball Joint Removal.
http://i42.photobucket.com/albums/e318/gum...ointRemoval.jpg
Pgreenlaw's Homemade Cam Tensioner
Make your own cam chain tensioner tool. 06+
http://www.trx450r.org/forum/index.php?showtopic=49822
(Thanks Pgreenlaw)
CALCULATORS AND UTILITIES
Valve Shim Calculator
Used to help determine the shim size needed to correct valve clearance problems.
http://crfsonly.com/calculators/crf450-valve-shim-calc.php
Displacement, Gearing, Piston Speed & Shim Size Calculator
Used to help determine displacement size, piston speed, MPH by gearing and shim size. Calculator is a downloadable EXE file to stored and run from your computer.
http://www.xcracing.com/gabe/quad_calc.exe
(Thanks 86atc250r)
GRAPHS & CHARTS
GRAPHS & CHARTS
Racing Fuel Mixing Chart
100 Octane Unleaded Racing Gasoline is the ideal fuel for the high performance enthusiast who requires unleaded fuel. With the use of this custom blending chart, you can economically reach the exact octane number your vehicle requires. First determine the octane number you desire. Then fill your tank with the number of gallons of Unleaded Super 92 octane. Unleaded gasoline enhanced with alcohol should not be used. Next add the number of gallons of 100 Octane Unleaded Racing Gasoline. Blending to the desired octane number will be automatically accomplished.
Jet Conversion Chart
(Thanks GPracer2500/cataway/TRX450rlude/El Duner)
