The Honda, and Hot cams are drop in cams which mean you can swap them out with out changing anything else. With the Megacycle and WEB cams you may need to change valve springs, cut valve guides, cut valve reliefs in the top of your piston depending on which one you choose.
Honda Cams
Honda 2004-2005 HRC Cam - Part # 14110-NLZ-650
Really strong to top end cam, with a decent mid range, but lacks bottom end.
Intake Lift(inches): .390
Exhaust Lift(inches): .350
Intake Lobe Center (degrees): 110
Exhaust Lobe Center (degrees): 105
Intake Duration (degrees at .040"): 260
Exhaust Duration (degrees at .040"): 260
Honda 2002 CRF Cam - Part # 14110-MEB-670
A good all around cam, strong bottom and really strong mid range with a decent top end as well.
Intake Lift(inches): .380"
Exhaust Lift(inches): .356"
Intake Lobe Center (degrees): 106.5
Exhaust Lobe Center (degrees): 107
Intake Duration (degrees at .040"): 249
Exhaust Duration (degrees at .040"): 272
Honda 2003 CRF Cam - Part # 14110-MEB-770 <-------------Now is 14110-MEN-670
A good mid range cam.
Exhaust Lift(inches): .336"
Intake Lobe Center (degrees): 109
Exhaust Lobe Center (degrees): 109
Exhaust Duration (degrees at .040"): 262
Honda 2006-07 HRC & Honda 2005 CRF Cam - Part # 14110-NLZ-610
Really strong bottom with a decent mid range.
Intake Lift(inches): .374"
Exhaust Lift(inches): .313"
Intake Lobe Center (degrees): 248
Exhaust Lobe Center (degrees): 268
HotCams
HotCams Stage 1 - Part #1016-1
Excellent bottom end and midrange increase.
Intake lift (inches): .378"
Exhaust lift (inches): .343"
Intake lobe center (degrees): 106.5
Exhaust lobe center (degrees): 103.5
Intake duration (degrees at 1mm): 237.5
Exhaust duration (degrees at 1mm): 268.5
HotCams Stage 2 - Part #1024-2
Excellent midrange and top end increase, good all-around cam.
Intake lift (inches): .402"
Intake duration (degrees at 1mm): 248
HotCams Stage 3 - Part # 1056-3
More top-end power than Stage 2. Will work well for TT and big bore/strokers.
Intake lift (inches): .409"
Exhaust lift (inches): .356"
Intake lobe center (degrees): 116
Exhaust lobe center (degrees): 104.5
Intake duration (degrees at 1mm): 251.5
Exhaust duration (degrees at 1mm): 265
Megacycle Cams
Megacycle X1 - Part # 108-x1
Race profile for increased mid to top end, must use race piston and valve springs. Intake valve pocket may need cut on piston.
Intake Lift(inches): .430"
Exhaust Lift(inches): .385"
Intake Lobe Center (degrees): 102
Exhaust Lobe Center (degrees): 106
Intake Duration (degrees at .040"): 266
Exhaust Duration (degrees at .040"): 282
Megacycle X2 - Part # 108-x2
Strong midrange / all-around. Must use race piston and valve springs. Intake valve pocket may need cut on piston
Intake Lift(inches): .412"
Exhaust Lift(inches): .350"
Intake Lobe Center (degrees): 108
Exhaust Lobe Center (degrees): 108
Exhaust Duration (degrees at .040"): 268
Megacycle X3 - Part # 108-x3
Full race cam max top end. Must use race piston and valve springs. Intake valve pocket may need cut on piston.
Intake Lift(inches): .435"
Intake Lobe Center (degrees): 104
Intake Duration (degrees at .040"): 276
Exhaust Duration (degrees at .040"): 276
WEB Cam Inc.
613/812 - Part # 57-102
Performance profile to increase mid and upper end power. Higher compression recommended. Must be used with performance spring kit shortened valve guides and adjustable cam gears.
Intake Lift(inches): .381"
Exhaust Lift(inches): .357"
Intake Duration (degrees at .050"): 240
Exhaust Duration (degrees at .050"): 258
493/729 - Part # 55-462
Intake Lift(inches): .415"
Exhaust Lift(inches): .340"
Intake Lobe Center (degrees): 276
Exhaust Lobe Center (degrees): 288
Intake Duration (degrees at .050"): 252
Exhaust Duration (degrees at .050"): 252
208/921 - Part # 57-042
Race profile. Higher compression required. Must use performance spring kit, shortened valve guides and adjustable cam gear.
Intake Lift(inches): .408"
Intake Duration (degrees at .050"): 282
Exhaust Duration (degrees at .050"): 298
Mysto - Part # 57-072
The "MYSTO" cam designed for race use ONLY. Higher compression required. Must use performance spring kit, shortened valve guides and adjustable cam gear. Check all clearances!
Intake Lift(inches): .432"
Intake Duration (degrees at .050"): 293
Exhaust Duration (degrees at .050"): 296
Johnson Cams
400 - 375 (Little Johnson)
Strong midrange and top end.
Intake Lift(inches): .400"
Exhaust Lift(inches): .375"
Exhaust Duration (degrees at .040"): 284
430 - 400 (Big Johnson)
Top end drag cam.
Exhaust Lift(inches): .400"
Exhaust Lobe Center (degrees): 110
Intake Duration (degrees at .040"): 274
Exhaust Duration (degrees at .040"): 289
If anyone sees a mistake or would like another cam added to the list, please PM me the info and I'll get it up ASAP.
Thanks,
Scott
